Subject: Cloth Room Presets
Crispycraft opened this issue on Sep 11, 2009 · 7 posts
Crispycraft posted Fri, 11 September 2009 at 3:27 PM
I was just given some cloth room presets (I guess that's what you would call them) and I installed them via the path that I was instructed to do so, but I don't see anything when I am in the clothing room. I opened the Python tab, but there was nothing there.
The path I was given was:
Runtime/Python/poserscripts/scriptsmenu
The trouble I found with that was that I didn't have the "scriptsmenu" folder so I made one. But Still nothing. Am I not searching in the correct place?
TrekkieGrrrl posted Fri, 11 September 2009 at 4:15 PM
 Which presets exactly? It always helps to be specific.
I have some I got from PhilC once. But I must admit that short of downloading them, I haven't tried them out so I'm not sure what format thery're in or what they do ...
Crispycraft posted Fri, 11 September 2009 at 4:27 PM
Yeah, I have the PhilC also, but I had just received some from Fugazi1968. They are all .py files. I did figure out that I could open the Python window and load them into script like that, but Fugazi1968 has them in his tool bar.
grichter posted Fri, 11 September 2009 at 4:30 PM
 Dumb comment. If you load new scripts in the scripts menu, you have to restart poser before they will show up.
You should have had a scripts menu. In Poser if you click on the scripts pull down at the top and to the right, do you see anything?
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
Crispycraft posted Fri, 11 September 2009 at 4:38 PM
There's no "Scripts" there. That's what I'm trying to tell you. LOL! And, yes, I did restart poser after installing them. Is there some kind of addon that I need for the scripts tool bar tab? And, no, there's no scriptsmenu folder in my poser unless it's not in the location noted above.
PhilC posted Fri, 11 September 2009 at 5:53 PM
Which version of Poser are you using? The "Scripts" menu started with Poser 7.
Crispycraft posted Fri, 11 September 2009 at 5:59 PM
Well that explains a lot! LMAO! Poser 6 is what I have. HAHAHA!!!
Man, that was a good catch, PhilC. That also relieves a lot of frustration. Man...like 1000mg of Ibuprofen just kicked in. HA!
I found that I can add them individually in the Python Script window so I guess that's what I will continue to do until I finally upgrade.
