3dtrc opened this issue on Sep 16, 2009 · 25 posts
3dtrc posted Wed, 16 September 2009 at 3:58 PM
A new build released today at GraphicAll.org...
http://graphicall.org/builds/builds/showbuild.php?action=show&id=877
Lots of bug fixes.
That's 7 updates this past 2 weeks...thank you DingTo.
Michael314 posted Wed, 16 September 2009 at 4:02 PM
Hi,
good news! Thanks for the heads-up, time to test the new blender!
Best regards,
Michael
3dtrc posted Wed, 16 September 2009 at 4:32 PM
A start-up default view
50parsecs posted Thu, 17 September 2009 at 3:35 PM
I've been an "outsider" for ages now; always amazed by what you talented folks could do with Blender, yet always put off by the "unconventional" interface. Looks like now is the time for me to try it again. :)
jartz posted Fri, 18 September 2009 at 12:19 AM
Really interesting.
Can't wait to try it out.
____________________________________________________________________________________________________________________________
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Silgrin posted Tue, 29 September 2009 at 7:32 AM
Quote - Can't wait to try it out.
Me, too... But when I d/loaded the 2.50 builds from Graphicall, they turned out to be 2.49 or even 2.48... What`s up? Can sb link me a txt explaining this, or give a word how it works?
Silgrin posted Tue, 29 September 2009 at 7:39 AM
Quote - A new build released today at GraphicAll.org... http://graphicall.org/builds/builds/showbuild.php?action=show&id=877
This build neither works on my WinXP. "Faulty initiation 0xc0150002".
3dtrc posted Tue, 29 September 2009 at 1:11 PM
Try this one from DingTo:
http://www.graphicall.org/builds/builds/showbuild.php?action=show&id=877
His is the only one I test out.
If you still have problems...you may need to install runtime components of Visual C++ libraries.
blender.org has the details there.
Edit: Oops, I see that was the link you downloaded.
I think you may have to install the Visual C++ libraries as detailed at blender.org.
I have never had an issue with this on XP pro sp2 and Blender.
3dtrc posted Tue, 29 September 2009 at 1:20 PM
Is that 64bit xp pro?
If so...
Note: This version requires Visual C++ 2008 SP1 Redistribution Package (x64). (about 5MB)
The 64bit release of Blender for Windows is still in a development stage: it doesn't support all possible features yet, like FFMPEG, OpenAL and Quicktime.
If this does not work, then someone else may have an answer...I'm still new at Blender.
Can not think what else is causing this error.
Silgrin posted Wed, 30 September 2009 at 3:37 AM
If so...
Well, I dont have 64bit, and I d/loaded 32bit Blender (or I hope so:<). Isn
t the pkg made for 64bit machines? I found sth else:
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-4A14-984D-389C36F85647&displaylang=en
What about these?
3dtrc posted Wed, 30 September 2009 at 12:21 PM
Ok...32 bit used.
Try deleting the custom default blend file b25.blend(in the .blend folder) and restarting blender.
I've been using 2.50 on xp pro sp2 all along with no problems.
What video card you have?...opengl version?...drivers up to date?...laptop or desktop?
Silgrin posted Thu, 01 October 2009 at 8:56 AM
Quote - Try deleting the custom default blend file b25.blend(in the .blend folder) and restarting blender.
Hmmm... No .blend fldr, no b25.* file :0 What`s wrong?!
Using http://www.graphicall.org/builds/builds/showbuild.php?action=show&id=877
DO you think a graphics card or its drived could crash an app on start?
3dtrc posted Thu, 01 October 2009 at 11:14 AM
Silgrin posted Fri, 02 October 2009 at 3:40 AM
Thx. Unfortunately, it repeated so many times I dont think another one would fix the thing. Do you know some other place where I could get B 2.50? Don
t the guys at www.blender.org have some test build repository?
BTW, the zip archive works w/o any error messages, so it seems they have some problem on their server??
3dtrc posted Fri, 02 October 2009 at 11:10 AM
Do you have,
Microsoft .NET Framework Version 2.0 Redistributable Package (x86)
installed?
Silgrin posted Mon, 05 October 2009 at 3:54 AM
Quote - Do you have, Microsoft .NET Framework Version 2.0 Redistributable Package (x86) installed?
1.1. Won`t work?
Gog posted Wed, 07 October 2009 at 3:32 PM
that interface makes me think so much of Max 3.1!
SEspider posted Fri, 09 October 2009 at 5:35 PM
Wish there was a way to get the scroll wheel to work.
hate not being able to move my view port.
Gog posted Sun, 11 October 2009 at 10:25 AM
@spider - what OS? my scroll wheel works in Windoze. (haven't tried an ubuntu compile...)
3dtrc posted Mon, 12 October 2009 at 5:53 PM
No...1.1 will not work.
A minimum of 2.0 .net is needed...which dates back to 2005.
http://en.wikipedia.org/wiki/.NET_Framework
Most software now(past few years) needs at least 2.0.
Give that a try.
3dtrc posted Mon, 12 October 2009 at 7:45 PM
Actually...you might want to try the latest download 23768 out today
It may fix your other display problem also.
Lots of fixes been done since 23285.
Check graphicall often.
Still going to need that .Net update though.
SEspider posted Tue, 13 October 2009 at 11:42 AM
Nope, still not working. I must be missing something. Did the controls for the Scroll wheel change?
I'm using the Windows7 Beta (activated)
Scrolling zooms in & out as normal as does pressing it to rotate around the mesh in real-time.
But The Shift + Scroll and the Ctrl + Scroll does Nadda (Nothing at all).
All updates and needed files installed but same issue continues to happen. 2.49b does not do this. Instead it gives me a menu lag (when you hover off of it).
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2782467
This bugs me. The 2.50 beta runs soooooo much smoother then 2.49 and later ever did. Same goes for it's lighting. :(
3dtrc posted Tue, 13 October 2009 at 12:30 PM
It's got to be a Windows 7 issue then.
I'm on XP Pro and plan to be using it for a long time.
I would go over to blender artist forums to get help there...probably more people using win7 there.
Enivob posted Fri, 30 October 2009 at 9:18 AM
I noticed that the scroll wheel only works on certain panels. Yep, it is still buggy and crashes quite a bit.
I am not a big fan of all that wasted interface space, how is this an improvement?
3dtrc posted Fri, 30 October 2009 at 11:03 AM
This release was 6 weeks ago.
There has been many releases sense then.
This is not even in beta yet.
This is not for SERIOUS WORK!
This is for TESTING ONLY!
Have you reported the bugs and crashes?
