bwtr opened this issue on Sep 24, 2009 · 10 posts
bwtr posted Thu, 24 September 2009 at 12:29 AM
Help and advice appreciated
Brian
bwtr
Pret-a-3D posted Thu, 24 September 2009 at 1:14 AM
I happened to me too and it's pretty frustrating. Some clips have just a bit of semi-transparent pixels at the edges. Cropping will not do. If you have After Effects you can load the clip in a comp, add a oval mask, keep it smaller than the size of the clip, about 8/10 of the size, feather the mask, probably around 20 pixels. Move the mouse outside the mask so that you can see the value of the pixels in the verify info panel. If the register at 0,0,0 then you are all set. Save the clip with a new name, load it in Carrara and it should work.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
MarkBremmer posted Thu, 24 September 2009 at 8:21 AM
You can skip the stock billboard and do the same thing with a vertex plane. However, with a vertex plan you can UV map it so the texture edge falls just outside of the geometry which will solve your problem.
Mark
bwtr posted Thu, 24 September 2009 at 5:10 PM
Thanks Preta and Mark.
I don't like UVs but I will give the idea a try.
Brian
bwtr
MarkBremmer posted Thu, 24 September 2009 at 5:15 PM
To know them is to love them. :-D
bwtr posted Thu, 24 September 2009 at 6:05 PM
bwtr
bwtr posted Thu, 24 September 2009 at 8:24 PM
Mark
In trying the solution relating to the movie in my first post, I found some problems in trying to use the Sparrowhawke Follow Terrain with the Vertex Plane idea.
However, I found you could change the Billboard (dont know about the Splat) into a Vertex object and do the UV thinghy to it. Then the Follow Terrain worked ok!
Life is strange!
Brian
bwtr
bwtr posted Thu, 24 September 2009 at 9:56 PM
The explosion sequence is on a Vertex Plane and travells from L to R.
The mouse walk sequence (R to L) is on the vertex adapted Billboard using the Sparrowhawke Follow Terrain.
The background is just a jpeg Backdrop behind the simple Terrain
Brian
bwtr
MarkBremmer posted Thu, 24 September 2009 at 10:10 PM
For the explosion, try duplicating the color channel into the glow channel but dial down the texture intensity to about 10 percent to help illuminate it. Just rambling...
bwtr posted Thu, 24 September 2009 at 11:31 PM
Yes. And I applied a Value of 10% at frame 1 and 90% at the last frame.
A VERY interesting modification to the visual effect of the original.
Thanks again.
Brian
bwtr
