Subject: Poser 8 - Why is UNDO not for unloading items?
mackis3D opened this issue on Oct 04, 2009 · 5 posts
mackis3D posted Sun, 04 October 2009 at 11:38 AM
Before the SR1 Poser 8 had a problem to undo certain moves (pose) at 'edit'.  This seems to be better now with SR1. But it still has problems to unload items. I had this problem not with Poser 7 or Poser Pro.
I'm loading a scene, but when I add a prop or figure (load), it does not unload them, when I want to undo with 'edit'. This is unnerving especially when a figure loads with lots of props, that are not parented. This happens just with the second, third or four step - even though my preference is set at 100 undos. Any explainations?
PhilC posted Sun, 04 October 2009 at 11:49 AM
Have you tried using the Poser 8 history option?
Scripts > P8_History
mackis3D posted Sun, 04 October 2009 at 12:33 PM
Yes, I tried also the P8_History option, but it does not show when a figure was loaded into the scene.
Strange.
And I have to correct myself: when I use a preset 'pose' for a figure like Poser James it's not possible to undo that pose,  I have to use another pose!
I wonder that no one else has discovered that, because it's something that must be obvious to everyone who poses the figures with preset poses.
So that is like it was before SR1. But it worked in Poser 7 and Poser Pro...
PhilC posted Sun, 04 October 2009 at 12:42 PM
I'm sorry but I'm unable to recreate your experience. For me undo and the history window are working as expected. Did you mouse over the history window to get it to refresh?
Anyone else having the same difficulty?
mackis3D posted Sun, 04 October 2009 at 12:48 PM
PhilC, thanks for bringing 'refresh' into my mind, it brought me to the solution, the library. Now I know why it's not in the history window: Because I loaded the items with 'XL-eXtended Library'! That is the problem!
With the real P8 library the undone for loaded items appear in the history and it can be undone under 'edit'. So the XL has to go, it's unusable when it conflicts with Poser's undone history.
