AtelierAriel opened this issue on Oct 06, 2009 · 8 posts
AtelierAriel posted Tue, 06 October 2009 at 3:14 PM
Can anyone tell me how to create a .pz2 that will just change the kd color without removing all of my shaders?
I already have a pz2 that has all of the kd color statements only and it works. But I need to know if there's a line I can add that will tell Poser to leave the textures and shaders alone and just change the kd color.
All I want to do is have a pz2 to alter the shade of the existing textures.
Anyone know how to do this, thanks in advance.
AA
TrekkieGrrrl posted Tue, 06 October 2009 at 3:44 PM
So your pz2 can alreadt change the base colour, right? But also changes the texture? Hm. I would have thought that stripping out the lines that had to do with the texture should give a file that wouldn't touch those, but that is probably what you've already tried...
Can you post an example of your PZ2? It's always easier when you can see and discuss the actual example :)
bagginsbill posted Tue, 06 October 2009 at 3:46 PM
I've tested this. Poser replaces the entire shader with whatever it says in the material section(s). That means you lose nodes of any kind.
The only way i know to do this is to write a Python script to do the incremental changes and then a matching pz2 to call it. It means having to make two files for each color, but the pz2 is trivial.
markschum posted Tue, 06 October 2009 at 3:48 PM
I believe a mat pose or a material file will replace the shader nodes rather than add or change them . Theres a bunch of (well several) python scripts to change things in the shader tree without blowing it all away.
http://www.sharecg.com/v/23657/Script/Set-diffuse-gray-script-,-for-light-set
theres one that sets all materials diffuse color the same . Edit the diffuse value for whatever color you want.
AtelierAriel posted Tue, 06 October 2009 at 5:18 PM
I've tested the pz2 every which way I could and it still removes the shaders. It will leave the color texture and bump if you have one. Very strange.
I did think of a script which would be easy to find but don't know how to write a pz2 to call it. Can write a pz2 but have never done that.
TrekkieGrrrl posted Tue, 06 October 2009 at 7:52 PM
In this thread is explained (hope the link works, otherwise.. it's a good part down at the page...) how to call a python script from a pose file http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2735605&page=3#message_3217877
AtelierAriel posted Tue, 06 October 2009 at 9:30 PM
Thank you so much!
markschum posted Tue, 06 October 2009 at 10:32 PM
If you want to change the color of the same item you can save the material and make several variations all using different diffuse colors all with the full shader setup.
