xantor opened this issue on Oct 13, 2009 · 5 posts
xantor posted Tue, 13 October 2009 at 11:03 AM
For example, the picture shows a tube and a thin box, the centre of the box is not the rotation point, how do I find a specific point in the box to put the pivot point?
This happens a lot with mechanical objects I make where it is difficult to find the exact rotation centre so it would be great if anyone has a solution.
PhilC posted Tue, 13 October 2009 at 11:16 AM
I usually set the preview style to wire frame then use one of the orthographic cameras and the joint parameter editor to position the center where I require.
xantor posted Tue, 13 October 2009 at 11:19 AM
Quote - I usually set the preview style to wire frame then use one of the orthographic cameras and the joint parameter editor to position the center where I require.
That is what I usually do as well, but I was hoping that there would be a better way.
markschum posted Tue, 13 October 2009 at 11:25 AM
Yup, thats the only way I know to do it.
It is possible to write a script to scan the geometry , get the bounding box , and find its center but just visually is usually good enough.
xantor posted Tue, 13 October 2009 at 12:03 PM
Quote - Yup, thats the only way I know to do it.
I already have a python script that finds the centre of objects, but asymmetrical objects and ones that don`t have the pivot point in the centre are difficult to get right.
