![](https://live.cdn.renderosity.com/forum/_legacy/file_165632.gif)
Ok, Here's my try at an A to B animation using only two key frames. If you count time zero as a key frame then there are two but I cheated trying to be tricky using a motion path. The motion path thingy in Carrara is either very difficult to understand or very rough or both. I used the plane I made in the 100 minute challenge except I changed the prop.
-Kix
![](https://live.cdn.renderosity.com/forum/_legacy/file_165633.gif)
Well I couldn't help it so I decided to fuss around with the motion path stuff some more, moved the camera a little bit and straightened this out some. This motion path thing is sure twitchy and hard to figure. Does anybody else have these sorts of problems?
-Kix
