cfpage opened this issue on Oct 19, 2009 · 8 posts
cfpage posted Mon, 19 October 2009 at 11:14 AM
Never had any real problems with P7 and the ones I did I was able to correct with reading post's
or fix my self. Till now.
I had to do a fresh re-install and set up everything like before, main runtime and my other runtimes
so I setup a sceen save it, when I came back to work on it, problem loading texture (can't find it)
even if I save to fig to libary reload, save sceen , re-open same thing. mainly with hair figs,
this never happened before, with the same setup, before my reformat fresh install. any Ideas ?
Propschick posted Mon, 19 October 2009 at 11:21 AM
Go to general preferences, library and choose shallow search - see if that works - it should
Ever stop to think,
and forget to start again?
hborre posted Mon, 19 October 2009 at 11:55 AM
Shallow search? Usually deep search corrects such problems.
Propschick posted Mon, 19 October 2009 at 12:03 PM
Ahhh I usually test on shallow as deep skips over actual real file calls
Ever stop to think,
hborre posted Mon, 19 October 2009 at 12:14 PM
OK, just confused by the response. Thanks for the enlightenment Propschick.
Propschick posted Mon, 19 October 2009 at 12:15 PM
Glad I could enlighten and remove the confusion =)
Ever stop to think,
cfpage posted Mon, 19 October 2009 at 1:28 PM
Quote - Go to general preferences, library and choose shallow search - see if that works - it should
I had tried that before,only this time I re-booted pc and seems to be working now, thanks
for the help.
Propschick posted Mon, 19 October 2009 at 1:50 PM
hope it stays working good for you
Ever stop to think,
