Forum: Animation
Subject: Animation to PNG slides
gojakv opened this issue on Oct 26, 2009 · 6 posts
gojakv posted Mon, 26 October 2009 at 12:47 PM
HI,
please, can anyone tell me (what software to use) how  to produce PNG pictures for each frame of 60 frames Poser animation. I use Premiere, but it has no export option for what I need. Exporting frames as pictures from Premiere gives them reduced quality. I would like to skip rendering each frame with Firely Render from Poser. It would take me hours to produce 60 PNG pictures.
Thank you!
Miss Nancy posted Mon, 26 October 2009 at 3:16 PM
they may have already answered this in poser forum, but it takes the same amount of time to render an uncompressed video as it does to render a series of uncompressed image files AFAIK.  the advantage to rendering series of image files is that poser may crash during the rendering.  if it crashes during a video render, you have nothing, but if it crashes during an image sequence, at least you have the first few images.
just between you and me, poser is the most crash-prone app I have ever used.  I know some will deny this, but it's just a lame attempt to shift blame from the coders to the user.
markschum posted Mon, 26 October 2009 at 5:41 PM
The render time should be the same for 60 frames of the same dimensions as still images or as a video.
www.videohelp has a lot of info and links to free tools (and shareware or commercial)
http://www.videohelp.com/tools/ffmpeg   may do what you want.
gojakv posted Tue, 27 October 2009 at 12:31 PM
Thanks!
gojakv posted Thu, 29 October 2009 at 6:41 AM
Thank you all. Anyway, I have found simple solution by myself. ACDSee Pro2.5!!!
How could I forget about that?! :)
gojakv posted Thu, 29 October 2009 at 8:00 AM
Quote - they may have already answered this in poser forum, but it takes the same amount of time to render an uncompressed video as it does to render a series of uncompressed image files AFAIK.  the advantage to rendering series of image files is that poser may crash during the rendering.  if it crashes during a video render, you have nothing, but if it crashes during an image sequence, at least you have the first few images.
This post was deleted in Poser forum.
