Subject: How can i turn a 3ds figure into a poser model?
haegerst opened this issue on Oct 30, 2009 ยท 4 posts
haegerst posted Fri, 30 October 2009 at 7:02 PM
Hi there!
Is there a way to turn a 3ds model of a figure into a poser model? I have a figure in 3D Studio max 7, but i am a big fan of poser. I would like to turn the Max model in a poser figure. I have not yet added bones in max, i thought it would probably only work when i do it in poser. But i must admit i have no clue where to start, i have imported the 3ds export fine and it looks great but it's a solid rock statue, unposable. Do i also have to define own magnets, morph targets and so on or is there a way to easily apply them to the 3ds. I am sure others have gone through this before, but i could not find a matching tutorial. Any tip? Help! :(
Vue content creator
www.renderarmy.com
markschum posted Fri, 30 October 2009 at 7:21 PM
If you group tyhe model you can use phibuilder to create the figure, or load all the bodyparts in poser, set the hierarchy with hierarchy editor and then create a figure from that (its at the bottom.) then tweak your joint zones and add morphs .
http://www.sharecg.com/share.php?upload_section_id=1&upload_type_id=11&upload_id=32860
its an old old document but still works in Poser 7.
pakled posted Fri, 30 October 2009 at 7:58 PM
you might consider changing the format to .obj, which is more common in Poser. Blender, xroads, Wings 3d, and almost any modeler should be able to convert them.
Miss Nancy posted Sat, 31 October 2009 at 6:40 PM
haeg, please post render of model in max, that we might see what it looks like.
