GroZZleR opened this issue on Nov 04, 2009 · 3 posts
GroZZleR posted Wed, 04 November 2009 at 5:51 PM
Hey all,
Is there a way to render an image without lighting but still have the figure be coloured? When I turn off all the lights, the figure becomes completely black. I'm trying to render some game sprites and lighting would ruin the way the figure looks while rotated.
For example: If I render the figure from overhead, when I rotate the sprite, the shadows move with the sprite despite the fact the sprite hasn't moved through the scene.
I can provide a picture if that's not very clear.
Thanks guys!
markschum posted Wed, 04 November 2009 at 6:25 PM
Turn off shadows for the lights.
I render preview animations using three spotlights , all ligt grey color, spaced at 120 degree pointing at the center where my figure is rotating. Positioned slightly above and pointing down about 30 degrees. Spotlight start angle 70 , end angle 140 .
With this setup you will still get some small specular changes as the model is turned.
With Poser 7 or 8 you could use Image based lights or GI.
Kalypso posted Thu, 05 November 2009 at 12:52 AM Site Admin
In Poser 8 load a skydome prop and delete the lights. Make sure you choose IDL in your render settings and adjust tone mapping to your liking. You will get a globally illuminated render.
You can use Bagginsbill's environment sphere found here: http://sites.google.com/site/bagginsbill/free-stuff
