AnyMatter opened this issue on Nov 08, 2009 ยท 4 posts
AnyMatter posted Sun, 08 November 2009 at 3:19 AM
hi,
i've been making videos with daz studio. animate+ together with pupeteer are really satisfied as a motion tools. btw, i had problem with daz studio camera. im plan to move the camera with proper path continiously througout the animation. however as i rotate the camera to desired view, the camera turn wildly in certain frame, espacially the frames that camera is rotating.... i wonder does daz studio provide a graph editor(like in poser) to adjust the motion?? otherwise, how to properly control camera in daz studio? any help is appreiated! thanks!!
RHaseltine posted Sun, 08 November 2009 at 8:41 AM
There isn't a graph editor. Depending on what you want to do, ne option is to parent the camera to a null and move/rotate that.
animajikgraphics posted Sun, 08 November 2009 at 10:51 AM
Since you have Animate+ you can use the "Object" aniblocks to move the camra. By adjusting speed and combining the basic moves on different tracks you can animated the camera this way. Other that than, the method RHaseltine mentions is best for doing it by hand.
There's also a 3rd party plug-in called "Key Grip" that reportedly helps with camera movement. Have not tried it so can't vouch for it.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
animajikgraphics posted Sun, 08 November 2009 at 10:53 AM
Also, once you use AniMate+'s object blocks, you can use Animated+'s built-in Graph Edotor on those blocks as well - forgot to mention this.
