redtiger7 opened this issue on Nov 17, 2009 · 7 posts
redtiger7 posted Tue, 17 November 2009 at 3:57 PM
I just installed SR2 on P8, and now instead of a library, I get an IE error page. And yes, my firewall is set to allow P8 access to the trusted zoone and internet
nruddock posted Tue, 17 November 2009 at 4:13 PM
If Poser.exe has changed, you may need to reallow it in you firewall software (as some firewalls check to make sure allowed EXEs haven't change which is generally a good idea).
redtiger7 posted Tue, 17 November 2009 at 4:18 PM
Nope. Have two Poser8.exe entries in Zone Alarm, and they're both given access. As is SR1 and 2.
I switched over to ask, then back to allow and still have the problem.
ockham posted Tue, 17 November 2009 at 5:23 PM
Same thing here.
Little_Dragon posted Tue, 17 November 2009 at 5:30 PM
Try right-clicking inside the IE error page, and choose "Refresh" from the list of options.
ockham posted Tue, 17 November 2009 at 6:13 PM
Well, the problem solved itself for some reason. I started up P8 to try your suggestion,
and it went through a minute of really weird "repainting" action, then came up with the library showing properly!
redtiger7 posted Tue, 17 November 2009 at 9:36 PM
Refresh seems to have worked.
This ticks me off, I shouldn't have to hit refresh. The library shouldn't have these kind of problems
