Vex opened this issue on Nov 18, 2009 · 18 posts
Vex posted Wed, 18 November 2009 at 4:04 PM
Just wondering what your render times are with an IDL quality higher than 2. lol.
I'm on a 2.4ghz core 2 duo with 4gb ram and im sprouting cobwebs waiting :/
bagginsbill posted Wed, 18 November 2009 at 4:43 PM Online Now!
What are you using for the Irradiance Cache value? It can be much lower for IDL than AO.
Vex posted Wed, 18 November 2009 at 4:57 PM
100 lol.
i thought it had to be 100 for idl to make shadows?
bagginsbill posted Wed, 18 November 2009 at 5:01 PM Online Now!
No, what that means is you told Poser it is not allowed to speed up IDL by using cached values. You're forcing it to calculate IDL luminance and shadows for every single point in the scene, including points you can't see that are needed to figure out the total bounced lighting.
Try 5. If it looks wrong, try 10, and so on. It will be way faster.
Vex posted Wed, 18 November 2009 at 5:04 PM
oh neato. okies :D
thank you.
for quality I should put it on 100 ?
bagginsbill posted Wed, 18 November 2009 at 5:07 PM Online Now!
No try 7.
bagginsbill posted Wed, 18 November 2009 at 5:14 PM Online Now!
IC=100
ILQ=7
Time: 424 seconds
bagginsbill posted Wed, 18 November 2009 at 5:15 PM Online Now!
IC=10
ILQ=7
Time: 23 seconds
Vex posted Wed, 18 November 2009 at 5:15 PM
i've tried 2, 25, 42, 70.. it all leaves awkward gaps in the "ao" type shadows around her clothes.
its rendering right now ( precalculation went WAY faster with lower IC )
bagginsbill posted Wed, 18 November 2009 at 5:17 PM Online Now!
Time: 14 seconds
So IDL is only costing 9 seconds.
bagginsbill posted Wed, 18 November 2009 at 5:18 PM Online Now!
Quote - i've tried 2, 25, 42, 70.. it all leaves awkward gaps in the "ao" type shadows around her clothes.
You may be experiencing the IDL 90-degree artifacts, which cannot be dismissed via higher render settings. This is a bug that SM is working on.
I'd have to see what you're getting to be sure.
bagginsbill posted Wed, 18 November 2009 at 5:22 PM Online Now!
bagginsbill posted Wed, 18 November 2009 at 5:25 PM Online Now!
Vex posted Wed, 18 November 2009 at 5:29 PM
bagginsbill posted Wed, 18 November 2009 at 5:32 PM Online Now!
Yep - that's the bug.
Vex posted Wed, 18 November 2009 at 5:39 PM
so if i tackle it with the morph tool and change it from a 90º angle it will behave?
bagginsbill posted Wed, 18 November 2009 at 5:43 PM Online Now!
Maybe. Or moving the cloth away a tiny bit might fix it.
Vex posted Wed, 18 November 2009 at 5:46 PM
i really like IDL.
it makes me feel like im not using a $250 piece of software.
