Forum: Freestuff
Subject: Daddy are we there yet? = Questions about a potential freebie
pakled opened this issue on Nov 21, 2009 · 9 posts
pakled posted Sat, 21 November 2009 at 11:24 PM
This is mainly an inside joke (Bobby Stahr will get it..;) but I've been playing around with the Spline tool in Anim8tor (long story), and came up with this chair.
Textures by Tyllo and Tony Lynch, but the design is mine. I realize the fabric is off-center (not sure how to get it 'on-center'...;) but the cushions don't deform too much (this is P5, production mode).
Feel free to eviscerate the design, or supply good ideas for improvement.
Whazizname posted Sun, 22 November 2009 at 1:04 AM
Interesting chair; not something that would see a lot of use in my images; but still quite nice looking!
The texture "off centeredness", can be cured by adjusting the appropriate offset parameter in the "image_Map" node.
If you suspect that the Firefly render engine is the cause of the deforming of the cushions; that can be cured by deselecting "Smooth Polygons" in the chair's parameter tab.
Uhh...; what was the question?  Oh yeah, nice looking chair!
Lucifer_The_Dark posted Sun, 22 November 2009 at 2:05 AM
Is it just me that sees removing the cushions would turn the chair into the perfect Spanish Inquisition torture tool? It looks good by the way, even with the slightly squiffy textures. ;)
Windows 7 64Bit
Poser Pro 2010 SR1
ThunderStone posted Sun, 22 November 2009 at 6:46 AM
It's what's known as "The Comfort Chair" an inside joke with the Brycers... as well as the Monty Pythoners. 😉
Oh btw, it's a nice looking chair... Of course if you make the round thingy into a square thingy is would be looking more ferocious and uncomfortable.
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
pakled posted Sun, 22 November 2009 at 10:03 AM
thanks....
offset parameter...image mode? I probably should mention that it was done in Wings 3d, and rendered in Poser 5 (it's all I can afford...;)
Which program are these in? and what tab? and can you do this while standing on one foot?...;)
Inquiring minds want to know...;)
thanks again.
Whazizname posted Sun, 22 November 2009 at 10:30 PM
Heheh!
I can't do it while standing on one foot; but I've heard of it being done that way.
The possible cures that I mentioned are all for Poser 5 (that's all that I have afforded...)
The image node, and offset parameters are found in the Material Room. (see image) Changing offset values will cause the applied image to move (U offset equals horizontal movement, Y offset equals vertical movement).
The "Properties" tab (excuse me, I used an incorrect name in my previous post...) Is the other tab on the window with the dials (in fact, the window with the dials is the "Parameters" tab.) It is normally seen in the Pose Room; but can in fact be active in an "room". (see image)
Whazizname posted Sun, 22 November 2009 at 10:32 PM
...and the Properties tab...
pakled posted Wed, 25 November 2009 at 1:00 AM
you are da man (unless you're a woman...;) Will check this out. Interesting notion. I too, have the other working copy of P5 still in existence...;)
coolness...
Whazizname posted Wed, 25 November 2009 at 6:25 AM
Heheh!
I happy that I could help.
