paomarnn opened this issue on Nov 23, 2009 · 4 posts
paomarnn posted Mon, 23 November 2009 at 5:23 AM
hi all,
is it possible to have lightning inside volumetric storm clouds?
not the bolt, but the flash that lights the clouds?
thank you in advance
agiel posted Mon, 23 November 2009 at 5:46 AM
That should be possible.
You can set Spectral Clouds to be influenced by lights in your scene. Between that and playing with the density of the cloud materials, you should be able to have a good control on adding lights inside of clouds to simulate lightning.
paomarnn posted Mon, 23 November 2009 at 10:11 AM
thank you agiel
i 'm new about vue xtream 7.
i' have to learn the new features of spectral clouds.
Rutra posted Mon, 23 November 2009 at 1:06 PM
Quote - "You can set Spectral Clouds to be influenced by lights in your scene."
It's not exactly like this. In fact, it's the other way around: you have to set lights to influence clouds. You do so by clicking on the little cloud icon on the object properties panel when your light source is selected. The object properties panel is on the right side of the screen, the top section.
If you don't click on this icon, the light won't influence clouds.
