beos53 opened this issue on Dec 04, 2009 · 5 posts
beos53 posted Fri, 04 December 2009 at 11:39 PM
Is there anyway to save all Facial animation
When I went to save my animation I selected my subset
I unchecked everything except for anything having to do with the head
Saved the animation and applied it to the same character (after first removing any animation from the figure)
The head moved the eyes sorta moved (they didn't close all the way and the mouth didn't have an open smile (my original animation the eyes did close and there was a smile at certain points)
Is it possible to save All the Facial animation in Poser?
Thanks fo any info
Steve
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia
GeForce GTX 750 Ti
Adom posted Sat, 05 December 2009 at 7:50 AM
What about saving to the "face library" - I'm not quite sure about it but you can give it a try.
ockham posted Sat, 05 December 2009 at 9:09 AM
Yes, you can save a multi-frame animation in the Face (or Expressions) library.
It's not used much, but it's possible.
chriscox posted Sat, 05 December 2009 at 9:09 AM
It sounds like you may not be saving the pose with the Morph Channels selected. If that's the case when you save the pose ensure that you select the "Morph Channels" option.
beos53 posted Sat, 05 December 2009 at 1:31 PM
I was trying to save the face animation in the Pose folder and I had tried saving with Morph Channels selected and also unselected.
I did save it in the Expressions) library. and it worked
Thank all of your for your input
GeForce GTX 750 Ti
