Subject: Need help saving (and loading) expression and poses.
melovewrestling opened this issue on Dec 06, 2009 · 4 posts
melovewrestling posted Sun, 06 December 2009 at 4:06 PM
Greeings people :)
Well i have a big problem here :( I've been creating a lot of poses and expression, and I have got them saved under the poses and expression directories. Originally everything was fine, no matter how many times i turn off and on poser, they are always there in the content menu and loadable.
However the problem come when I reinstall the poser and trying to restore it. I back up the whole runtime folder, so basically everything i had before, are still here, clothes, characters, etcetc, except the poses i created.. I went to the folder with window explorer and realize that there were actually nothing over there!
So i am wondering if the custom made poses or expressions are saved in some other folders which is different from the one shown in the content menu?
Any help will be greatly appreciated! (i lost so many expression and poses) :..-(
Cheers
hborre posted Sun, 06 December 2009 at 6:19 PM
Elaborate on which Poser version and OS you are currently using.
melovewrestling posted Mon, 07 December 2009 at 1:06 AM
hm, it is poser 6 and i am using window vista ultimate
hborre posted Tue, 08 December 2009 at 12:49 PM
From what I understand, Vista is notorious for allowing any changes to occur within the Programs File Folder without proper authorization through its UAC.  With that said, if you have installed your Poser 6 within the aforementioned folder, there is a very strong likelihood that your saved files have been relocated to another folder.  I do not use Vista and I do not recollect where the new default folder is located.  Hopefully some one else can jump in and steer you in the right direction.  This has been posted before sometime ago.
