Subject: Character INJ does not respond V4.2
Eagle_hawke opened this issue on Dec 13, 2009 · 5 posts
Eagle_hawke posted Sun, 13 December 2009 at 8:40 PM
 Ok does anyone know why a character INJ pose wouldn't work? The req are V4.2 and Morphs++, both of which I have. I'm running Poser 8 and the Character is RDNA Zariah. It gives no errors nor does it try to locate missing files it acts like it's loading but nothing happens.
I have had this happen with a few other models so I'm not convinced this is an error with the Character as much as some glitch with V4.2 or Poser. Any Ideas?
Medzinatar posted Sun, 13 December 2009 at 10:04 PM
For the head, it only injects one custom morph under community, RMZarH3, with value set to 1.0
Do have morph present with that value?
Eagle_hawke posted Sun, 13 December 2009 at 10:33 PM
 no there's no RMZarh3 present. I have located the pz file in "RuntimeLibrariesRMMorphsRMZariah" where it should be, but it's just not loading.
Medzinatar posted Sun, 13 December 2009 at 11:20 PM
Head morph is loaded into last of community channels, PBMCC_50
If for some reason, you don't have that channel in model, it won't take.
For test, load V4 and morphs++ and save temporary figure back to library under some name like "test".  Open in "test.cr2" in text editor and search for string PBMCC_50, or maybe just PBMCC so you can see how many you actually have.
lesbentley posted Mon, 14 December 2009 at 5:35 AM
Try running the "Update Victoria 4.2 Base", you should find this on your desktop. Many morph packs require you to run the updater after installing the morph pack.
