Blue_Boy opened this issue on Dec 17, 2009 · 4 posts
Blue_Boy posted Thu, 17 December 2009 at 12:33 AM
Thanx for any advice
nruddock posted Thu, 17 December 2009 at 2:40 AM
Quote - ... and I am also puzzled as to why in the error message reads GS_Shovels_B.jpg.jpg should there be a double jpg at the end
That would appear to be the problem, so it's a mistake in the file you're trying to load.
Try opening the file in a text editor and (assuming it is a text file) you should be able to correct it.
You might also want to report the defect to DAZ.
Moilly posted Thu, 17 December 2009 at 7:50 AM
I had this problem a long time ago and worked out that it was due to editing the cr2 file in wordpad or notepad. It had the habit of putting an extra .jpg extension on the end of the file. I solved by using Open Office or the Windows or any equivalent word processors.
Notepad and Wordpad can't handle some of the larger files (and even some of the smaller ones)
Blue_Boy posted Thu, 17 December 2009 at 11:02 AM
Thanx to both of you
