blueblott opened this issue on Dec 20, 2009 · 3 posts
blueblott posted Sun, 20 December 2009 at 1:45 AM
Hello and the seasons greetings to all,
I am trying to get my camera to ...Rotate.
I have Daz 3 advanched.
Can I create a path for say camera 1 to follow around an object ?
Cheers
RHaseltine posted Sun, 20 December 2009 at 8:47 AM
Depends what you mean - you can set a camera to point at an item, or to point at a null which you then parent to an item (this gives a bit more flexibility) if you want to have it track, or you can animate movements of the camera as you do other items, or you can parent a camera to another item (to achieve the effect of a camera mounted on a car for instance). There can be problems when the rotations hit +/-180 degrees, however, which may require manual tweaking.
blueblott posted Tue, 22 December 2009 at 10:24 PM
Thankyou R Haseltine,
Now I understand what I have to do.
Cheers
