Subject: Need advice with material node
shuy opened this issue on Dec 29, 2009 · 7 posts
shuy posted Tue, 29 December 2009 at 11:22 AM
I've created simple prop for fast render. I use it for presentations of models, faces, poses etc. as a simple environment. [ http://www.sharecg.com/v/38688/Poser/Simple-environment-prop-and-bacground](http://www.sharecg.com/v/38688/Poser/Simple-environment-prop-and-bacground) I always have problems with math fuctions and I'm not able to obtain effect which I need. It would be great if any material expert can advise me how can I obtain mountain shape with this prop.
RobynsVeil posted Tue, 29 December 2009 at 4:46 PM
That would be your displacement channel on the main PoserSurface node that will need to have some number put in it. The value will depend on your units (inches or feet or whatever) setting. Also, in the render, you will need to have a value in min displacement and also use displacement maps ticked.
Be aware that the entire surface will be affected, so the "mountains" will be over your entire surface.
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
shuy posted Tue, 29 December 2009 at 4:54 PM
I should not make you to download this prop from sharecg. Sorry.
There is no displacement map. Prop is made with half of cylinder. Material nodes you can see below.
I'b like to know which function should I use with P node to obtain mount/hill shape on transparency map.
RobynsVeil posted Tue, 29 December 2009 at 5:36 PM
I've actually downloaded your prop and have it loaded in Poser 7.
I'm still not clear what you are trying to do. I see a dish with walls. are the walls meant to be the mountains?
BTW, very clever use of textures...
Metaphor of Chooks
shuy posted Tue, 29 December 2009 at 5:49 PM
Quote - I've actually downloaded your prop and have it loaded in Poser 7.
Exactly. I'd like to use function which let me obtain weave looks like mountain on the skyline.
I suppose that I must interact P node with sth else. ATM I use P node with clouds - function step, but I do not like it.
RobynsVeil posted Tue, 29 December 2009 at 6:38 PM
I'm afraid I'm a bit out of my depth... I only ever use displacement for elevation of mesh, so this is a new wrinkle to me.
Anyone? (passing the baton)
Metaphor of Chooks
shuy posted Fri, 01 January 2010 at 6:35 AM
Maybe today, when everybody have 1 year more experience with Poser, I'll find solution ;)
Best wishes
