Subject: Importing content in Poser 8 question
TonyL opened this issue on Jan 02, 2010 · 12 posts
TonyL posted Sat, 02 January 2010 at 10:13 AM
Hi!
Just returned to Poser after a long hiatus and I see some things have changed, I hope for the better (grin).
I want to import some older content into the program. This is mostly made up of props. I have checked out the Import>docs props option but it doesn't seem to do what I want. Maybe it DOES but I'm just reading things wrong.
The stuff is all in a file called Runtime and has subfolders of objects, mats and such. I want these things to be available in the browser.
I hope somebody can help me out here because it is sure different than what I remember.
Tony
DarkEdge posted Sat, 02 January 2010 at 10:22 AM
If the main Runtime folder is already inside a zip file just unzip to your main Poser folder, usually under C:ProgramFiles: SmithMicro.
If your runtime folders are outside of a zip file, grab just the Runtime folder (and all of the folder/files nesteled inside of it) and zip it up....then unzip to your main Poser folder and everything will self install.
Hope this helps. 😄
TonyL posted Sat, 02 January 2010 at 10:33 AM
It's a rar file. I tried opening it into Runtime and got a long list of errors.
bagoas posted Sat, 02 January 2010 at 11:20 AM
Quote - It's a rar file. I tried opening it into Runtime and got a long list of errors.
This is compressed format, like a .Zip file. You can use WinRAR (or a Mac equivalent) to decompress it.
hborre posted Sat, 02 January 2010 at 12:10 PM Online Now!
The OP has not mentioned anything about ZIPPED content.  If Your content already exists in a separate external runtime, you can add that folder to your Poser app.  There are 2 methods.
Method 1 is shown above.
hborre posted Sat, 02 January 2010 at 12:14 PM Online Now!
Method 2, using the built-in script above.  This is practical if you have multiple external runtimes on your HD you would like to add automatically.
TonyL posted Tue, 05 January 2010 at 12:48 PM
Thanx, I'll try those. Sorry it took me so long to answer but I've been away.
Tony
taglag posted Sun, 10 January 2010 at 3:56 PM
I don't have this partners script on Poser 7 or 8.... Or it is not in the drop down menu...I must have something installed wrong :(
TonyL posted Sun, 10 January 2010 at 4:11 PM
It didn't work for me. I have it with 8.
Tony
taglag posted Sun, 10 January 2010 at 4:15 PM
humm, I hate to have to copy them all over from 7, the old fashion way.. it will take so long, and how does the compressed way work, would it not , if you zip up the entire runtime, also get the preferences as well ??
I have had that mess things up before... ?
taglag posted Sun, 10 January 2010 at 4:39 PM
I have always just done it the hard way, and copied everything over, but having heard of this new way I wanted to learn it.. :)
taglag posted Thu, 14 January 2010 at 10:08 PM
It was my fault.   Blond moment, was not looking right place..that is very nice, can use runtime from anywhere..Kool.. !
