Subject: Problem with Joint Editor in Poser 8
hemi4261 opened this issue on Jan 02, 2010 ยท 10 posts
hemi4261 posted Sat, 02 January 2010 at 10:13 AM
Hello, I posted this at DAZ but maybe some people here could be interested as well...
I have a question regarding the Joint Editor in Poser 8 SR 2.1. I have created a piece of clothing for V4.2 in Hexagon and have turned it into conforming clothing with OBJ2CR2. Worked out pretty well, but it needs some adjustment on the joints between hip and lthigh/rthigh for the "bend"-action.
Basically the InnerMatSphere needs to be moved a bit lower, I think. Now, when I just select (without even moving it!) the InnerMatSphere, the "Joint Center Point" (which was in the correct place before) drops to the origin point (0/0/0) in Poser (pic3).
I encountered the problem also with a freestuff panty I used for testing...
Maybe someone here can reproduce the problem. Try the V4 Basic Wear panties.
I just figured out that the problem is worse than I thought, I cannot enter coordinates (well, I can, but he doesn't react) for the center point, just adjust it by dragging and that is not very precise...
Any idea what could cause this?
Free Centaur morphs for V4,M4,M3,AM,A3 and the Daz Millennium Horse
