Subject: Help with "Parameter Dials"
azimakberali opened this issue on Jan 05, 2010 · 4 posts
azimakberali posted Tue, 05 January 2010 at 11:19 AM
I just created a simple Poser figure. (not an easy task!) I created the bones and grouped it in the Setup Room and adjusted the joints using the Joint Editor. So far so good. Everything seems to be twisting, turning and bending well. Now my question is this, how can I create a Parameter dial which will bend two or three body parts together? Like the "Grasp" dial on the hand of the Standard Poser Figure which makes all the fingers and the thumb, bend together. I want to create a similar dial for my character's hands so that I can make all his fingers bend together without having to adjust each fingers parameters individiually. Is it possible to create such a dial? If so, please explain to me how. Thank you so much :-)
