Subject: IDL Light Wall
bagginsbill opened this issue on Jan 07, 2010 · 82 posts
bagginsbill posted Thu, 07 January 2010 at 10:10 PM
Here's a little IDL amusement.
Add a one sided square. Set its scale to 1000%. Set xScale to 600%. This makes a wall.
Apply this shader.
bagginsbill posted Thu, 07 January 2010 at 10:11 PM
Duplicate it and move the dup away, making a hallway.
Add a ceiling, using another scaled square with a plain white material.
Render with no lights.
This done with Poser Pro 2010, with GC enabled.
RobynsVeil posted Thu, 07 January 2010 at 10:35 PM
So ambient_value at .5, ambient_color white appears to give off light. Light is reflected on the floor - I'm assuming no reflection is turned on for floor or ceiling? The figure appears to be illuminated by the wall "lights".
All just because you're using IDL. If you weren't, what, nothing would render except white squares where that wall is?
No even going to comment on the shader: it's just defining where the squares are going to be, is that correct?
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
pjz99 posted Thu, 07 January 2010 at 10:41 PM
Are speculars now aware of ambient, or does the figure have reflection on it?
My Freebies
SamTherapy posted Thu, 07 January 2010 at 10:54 PM
Yet another reason for me to want P8 and a new computer to run it on.  :(
Damn you, BagginsBill.  ;)
FightingWolf posted Thu, 07 January 2010 at 11:21 PM
Quote - Yet another reason for me to want P8 and a new computer to run it on.  :(
I understand just how you feel. with the exception of Poser 8. I have that already., but a new computer would make it 100% better. lol
Frederick
Poser By Design
dlfurman posted Thu, 07 January 2010 at 11:32 PM
Flipside to FightingWolf.
New PC, No Poser 8.....(Sigh)
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD space
bagginsbill posted Thu, 07 January 2010 at 11:39 PM
Not .5, but 5. The luminance of the white rectangles is hyper-white 5.
The floor is a diffuse and reflect, which means you're getting IDL diffuse light coming from those rectangles, as well as some specular reflection of those rectangles. Because the reflection is very low, the luminance of the reflections is in the unit range, despite the fact that the rectangles are hyper white.
If I turned off IDL, we'd see the white rectangles and specular reflections of them, but everything else would be black.
The shader is not just hyper white. It also has ordinary diffuse in it. (Think about one of those panels if the light bulb blew out. It would be white plastic, illuminated by the other panels, so it would diffusely reflect some of that.) So my shader is white plastic (diffuse) plus in the rectangles some seriously bright self illumination.
bagginsbill posted Thu, 07 January 2010 at 11:41 PM
Quote - Are speculars now aware of ambient, or does the figure have reflection on it?
The figure and floor have reflection on them. Specular nodes probably never be IDL aware. Specular nodes are just simplified models of reflection of traditional light sources.
bagginsbill posted Thu, 07 January 2010 at 11:46 PM
I actually threw this together because of the node tut discussion in the other thread we're talking in.
What is a subtract node for? Here are two of them. One was used to calculate the complement of the V coordinate. Why? Because I need to know how far I am from the top and from the bottom. Whichever is smaller, is the nearer edge. That's the job of the Min - which is smaller?
The other subtract node was to take that distance (to the nearest edge) and subtract .15 from it so that if I'm closer than .15, I have a negative number, and if I'm farther than .15 I have a positive number.
I then multiply that by 100 and clamp it. This gives me a sharp gradient from 0 to 1 that begins .15 V units from the nearest edge.
So subtract is for finding nearest edges, or for finding distance from a known coordinate, or for a billion other things.
Clamp was used to limit value to 0 to 1. (Robyn, you and CobaltDream know that was to force it to be a PBUF. None of the people here know what a PBUF is, so I have to explain it in more words. Someday, everybody will know what a PBUF is.)
Anyway, that gives me a horizontal band of white that I multiply with the white vertical bands coming from the tile node to get the rectangles the size I wanted them.
RobynsVeil posted Thu, 07 January 2010 at 11:51 PM
Quote - Not .5, but 5. The luminance of the white rectangles is hyper-white 5.
Need to have my prescription checked. I could have sworn it said .5. Which didn't make sense.
Ambient_value of 5... does this make white a super-colour? Well, how can it? 1 x 5... what the heck colour is THAT? Or are we not changing WHITE itself, but the behaviour of that channel?
Opening a can of worms...
BTW, this is what I was talking about in that other thread about "Basic Poser Node Behaviour"... THIS needs to be accessible somewhere central...
[EDIT] Dang, cross-posted...
Metaphor of Chooks
bagginsbill posted Thu, 07 January 2010 at 11:58 PM
white is just 1,1,1. Multiply times 5 and it's 5, 5, 5. Yes, that's a  hyper color (or super color as you said). Means the same as far as I'm concerned.
You and I have talked about this for a long time now. Hopefully it's sinking in. We can work with luminance values that we cannot directly see, but indirectly the effects are felt. The floor reflections are very low at 10%, yet they are bright - because .1 * 5 = .5. So the reflections are about half as bright as the maximum our monitor can display. The directly viewed rectangles appear to be 1, but they are 5.
bagginsbill posted Thu, 07 January 2010 at 11:59 PM
I spoke to SM tonight about these darn corner artifacts. They expect them to be fixed soon. There will be another SR for P8, and Poser Pro 2010 will never show these at all.
I would already have been doing a lot of tutorials about IDL, but these artifacts show up. I figure there's no use teaching all about IDL if it's going to change in order to fix this.
Believable3D posted Fri, 08 January 2010 at 1:46 AM
Um... where do I find that texture coordinate node?
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
Winterclaw posted Fri, 08 January 2010 at 2:06 AM
Silly question but what is give the gray part of the walls (light between the lights) that slightly cloudy look?  Is that a part of the artifacts you were talking about?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Believable3D posted Fri, 08 January 2010 at 3:15 AM
Well, dagnab it. I don't know how you did it, Bagginsbill. I can get a reasonable facsimile of what you did above, considering I didn't get that texture coordinate node. But I can't get raytraced reflections without adding a light.
______________
bagginsbill posted Fri, 08 January 2010 at 7:18 AM
Quote - Well, dagnab it. I don't know how you did it, Bagginsbill. I can get a reasonable facsimile of what you did above, considering I didn't get that texture coordinate node. But I can't get raytraced reflections without adding a light.
Heheh. And now you see first hand why I have written over and over and over again:
Uncheck REFLECT_LITE_MULT - it is bad - makes no sense - never let it be on
Uncheck REFLECT_KD_MULT - it is also bad
bagginsbill posted Fri, 08 January 2010 at 8:22 AM
The v_texture_coordinate node is New Node/Variables/v
pjz99 posted Fri, 08 January 2010 at 11:47 AM
Quote - Uncheck REFLECT_LITE_MULT - it is bad - makes no sense - never let it be on
The default for this should be off if it's never useful.
My Freebies
Believable3D posted Fri, 08 January 2010 at 12:34 PM
Quote - > Quote - Well, dagnab it. I don't know how you did it, Bagginsbill. I can get a reasonable facsimile of what you did above, considering I didn't get that texture coordinate node. But I can't get raytraced reflections without adding a light.
I saw your reference to that above, but I had no idea where these parameters even are.
______________
Believable3D posted Fri, 08 January 2010 at 12:35 PM
Quote - The v_texture_coordinate node is New Node/Variables/v
Ah, thanks. Makes sense, but not obvious. :)
______________
pjz99 posted Fri, 08 January 2010 at 12:37 PM
They're on the root PoserSurface node.  Reflect_Lite_Mult is on for every material by default.
My Freebies
Believable3D posted Fri, 08 January 2010 at 12:41 PM
Quote - > Quote -
Nevermind. Don't know why I couldn't see them earlier. Guess I was expecting them in a different place.
The KD_MULT was already unchecked... I'm guessing it's just REFLECT_LITE_MULT that is checked by default.
______________
Believable3D posted Fri, 08 January 2010 at 12:42 PM
Yeah, caught it, pjz, thanks. I must have been looking for them either on the reflect node or right together with the reflection value on the Surface panel.
______________
Believable3D posted Fri, 08 January 2010 at 12:46 PM
Er... I take it having that checked by default is a new wrinkle in P8 or PP2010 Beta? because I just realized that I never had to go looking for that in the old Poser Pro and I got reflections fine....
______________
pjz99 posted Fri, 08 January 2010 at 1:01 PM
I don't think it mattered until you got into P8's tone mapping or gamma correction.
My Freebies
Believable3D posted Fri, 08 January 2010 at 1:27 PM
Well, when I used Poser Pro, I used GC. Is there a different GC setup with the 2010 version, I wonder?
______________
Winterclaw posted Fri, 08 January 2010 at 1:58 PM
Quote - > Quote - Uncheck REFLECT_LITE_MULT - it is bad - makes no sense - never let it be on
If it should default to off, why does it default to on?
WARK!
pjz99 posted Fri, 08 January 2010 at 2:17 PM
Dumbness.
My Freebies
Miss Nancy posted Fri, 08 January 2010 at 2:37 PM
it's been checked by default since day 1 (poser 4).  old habits die hard.  back in those days all they had were refl. maps.
Anthanasius posted Fri, 08 January 2010 at 4:14 PM
Strange, usualy you always use Alt_Diffuse ... Why not in this case ?
Génération mobiles Le Forum / Le Site
Believable3D posted Fri, 08 January 2010 at 7:25 PM
FWIW, I just posted a larger version of this variation to my gallery. Rendered in just under 20 minutes with PP2010 Beta.
______________
bagginsbill posted Fri, 08 January 2010 at 9:36 PM
Quote - Strange, usualy you always use Alt_Diffuse ... Why not in this case ?
I usually have to do GC in the shader, which means I have to take over what the root node usually does.
The root nodes does not let me add GC to it after. There is nothing I can do to add anything after the root node.
So ... I usually do not use anything built into the root node. I use the Alternate_Diffuse channel, which is pretty much a channel that exactly defines the output, without any more interpretation by the root node. When you see me use the Alternate_Diffuse channel of the root node, and pretty much nothing else, you can assume I'm doing that because the Root node is useless to me, is no advantage, and I wish it were gone in that case.
However, with Poser Pro 2010, I do not need to do GC in the shader. It will be done after the root node automatically. Which means the Root node math is very helpful. It contains, built in, a Diffuse node, a Specular node, and lots of other things, and it adds them all together.
Do I need the root node to provide all these things? No - I can do them myself and add them together. But when the root node does the job of 5 other nodes, (so long as GC is taken care of by the renderer, not the shader) then I use the full features of the root node.
Dead_Reckoning posted Sat, 09 January 2010 at 6:37 AM
> Quote - Here's a little IDL amusement. > > Add a one sided square. Set its scale to 1000%. Set xScale to 600%. This makes a wall.
And What grreat fun this is to experiment with.
I have a question or two for The Jedi Master of Poser Nodes.
Is it possible to have something like a Wall texture surrounding the White Light Panels?
Is it possible to use something like the 3d Clouds Node for the White Panels?
I tried using Blender or the Ambient Color with limited sucess.
Thanks
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
Believable3D posted Sat, 09 January 2010 at 12:33 PM
I'm assuming is that what it comes down to is whether the mortar is tweakable.
I'm assuming one could plug texturing nodes into the Mortar_Color parameter (on the Tile node), no?
(I don't have time to open Poser @ the moment to test, but it sounds doable to my very limited knowledge.)
______________
rjjack posted Sat, 09 January 2010 at 12:48 PM
just plug your color/texture on the Tile node, Tile_1 Tile_2 or Mortar color , you must change the top math_function by a Color_Math otherwise you get only grey color
rjjack posted Sat, 09 January 2010 at 12:52 PM
Believable3D posted Sat, 09 January 2010 at 12:58 PM
That's pretty cool, rjjack. But I think mariner was asking about the mortar - the area *surrounding* the white panels.
This looks pretty bad, because I just threw a node on the Mortar_Color and didn't do much tweaking. But just had to make sure it could be done. :)
______________
Dead_Reckoning posted Sat, 09 January 2010 at 1:12 PM
> Quote - That's pretty cool, rjjack. But I think mariner was asking about the mortar - the area *surrounding* the white panels.
You are most correct.
Something like Wall paper or Paint that one would see in and Airline terminal.
It would also be most interesting "IF" the White Areas could having something like clouds or an Outdoor scene. Something like one may encounter when traveling through the terminal.
Cheers
DR
I really like how these panels work with a Character.
Aging Mike.
Thomas Jefferson
Dead_Reckoning posted Sat, 09 January 2010 at 1:17 PM
Mike in the Airline Terminal
Thomas Jefferson
Believable3D posted Sat, 09 January 2010 at 1:17 PM
Another quick example, with colour.
______________
Believable3D posted Sat, 09 January 2010 at 1:18 PM
My settings reflect the fact I was experimenting. Ignore the blue on the Mortar_Color.
______________
Believable3D posted Sat, 09 January 2010 at 1:20 PM
Hm, I guess that blue was doing something, but I'm guess it was acting in greyscale (?). Anyway, lots of fun to play with.
______________
rjjack posted Sat, 09 January 2010 at 1:23 PM
Quote - Hm, I guess that blue was doing something, but I'm guess it was acting in greyscale (?). Anyway, lots of fun to play with.
you use a math_function replace with a Color_Math the math_function_4
Believable3D posted Sat, 09 January 2010 at 1:26 PM
Thanks. That's not working for me so far. Only colour I'm getting is what I set the Ambient_Color at.
______________
rjjack posted Sat, 09 January 2010 at 1:38 PM
maybe this, plugged in the Diffuse_Color
Dead_Reckoning posted Sat, 09 January 2010 at 2:31 PM
Sweet
Could you show a capture of the Material room for this?
Thanks
How about a Caustic or Gel?
Thomas Jefferson
Believable3D posted Sat, 09 January 2010 at 2:34 PM
I think rjjack just means that's an image map plugged into Diffuse_Color.
______________
Believable3D posted Sat, 09 January 2010 at 2:37 PM
Heh heh. This is looking pretty funky. A render of an old render with texture plus reflection.
______________
IsaoShi posted Sat, 09 January 2010 at 3:25 PM
.. or you could use a procedural. This is one of bb's own shiny marble shaders, plugged into the PoserSurface node, and turning the internal diffuse off. (I did not bother to scale the marble to suit the wall, I just loaded and rendered).
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
Believable3D posted Sat, 09 January 2010 at 3:49 PM
This sort of thing could be usable if I knew how to have it tile horizontally and avoid texture stretching.
However, mariner, I thought your question had to do with placing images on the light sources, not the "wall/mortar" sections - like the lit billboards in public places.
______________
Dizzi posted Sat, 09 January 2010 at 3:58 PM
Quote - This sort of thing could be usable if I knew how to have it tile horizontally and avoid texture stretching.
adjust the scale and offset values of the texture node to do that... The changes depend on the size of your wall though.
ThunderStone posted Sat, 09 January 2010 at 4:44 PM
Can this be applied in Poser 7, using a work around like say an IBL setup?
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Tashar59 posted Sat, 09 January 2010 at 5:31 PM
BM
Ghostofmacbeth posted Sat, 09 January 2010 at 6:28 PM
I think Ihave to be doing something wrong with this. This is what I am getting ...
MyCat posted Sat, 09 January 2010 at 6:37 PM
Ghostofmacbeth, try increasing the IDL bounces. I used 4.
hborre posted Sat, 09 January 2010 at 6:46 PM
@ ThunderStone: No, this cannot be applied to P7 and IBL.  If you read the beginning of the post, it specifically needs IDL to work.  Without it, you will see the white rectangles and specular reflections but everything else will go black.  IBL does not work very well for interiors.
Believable3D posted Sat, 09 January 2010 at 7:07 PM
Ghostofmacbeth: Looks to me like (1) your ambience setting is relatively low (surely not 5.0?); and (2) you don't have functional reflections (are you having the same problem I had earlier? Make sure REFLECT_LITE_MULT is unchecked on your Poser Surface).
I've been rendering with considerably less than 5.0 most of the time, but the reflections add a lot of light too.
______________
Ghostofmacbeth posted Sat, 09 January 2010 at 8:50 PM
It was the reflect lite mult check for the most part it seems. At least somewhat. Thanks
bagginsbill posted Sat, 09 January 2010 at 9:39 PM
Don't forget, my render was Poser Pro 2010 with GC. You cannot get that brightly lit look with ETM alone. You must GC. Poser 8 doesn't have GC.
I see that the two-zone material is of interest, and you guys don't understand the general case of building two materials in one. I'll post on that tomorrow.
Michael314 posted Sun, 10 January 2010 at 3:49 PM
Hello,
AFAIK any material for Poser can be described by a matmatic script.
Also matmatic had that "mixer" build-in to mix complete materials.
Given that, it should be easy to combine any existing wall material with
the light patterns. Just use the pattern bitmap as the stencil.
Best regards,
   Michael
Dead_Reckoning posted Thu, 14 January 2010 at 3:36 PM
Have you ever done something like a Stained Glass Window?
You have had so many great materials in the past, hard to keep up with all of them..
I would think in a Hallway, room such as this scene, something with several colors in it to emitt light would be most interesting.
Cheers
DR
Quote - Don't forget, my render was Poser Pro 2010 with GC. You cannot get that brightly lit look with ETM alone. You must GC. Poser 8 doesn't have GC.
Thomas Jefferson
Tashar59 posted Thu, 14 January 2010 at 3:55 PM
I'll second that.
bagginsbill posted Thu, 14 January 2010 at 5:35 PM
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3525210&ebot_calc_page#message_3525210
Porthos posted Fri, 15 January 2010 at 4:50 AM
This is so cool, thanks BB.
I added a few props with the one sided squares! :)
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
bagginsbill posted Fri, 15 January 2010 at 6:14 AM
Looks good Porthos.
Dead_Reckoning posted Fri, 15 January 2010 at 7:35 AM
Quote - http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3525210&ebot_calc_page#message_3525210
Thank you for the link. Somehow I must have missed that topic.
Cheers
DR
Thomas Jefferson
Dead_Reckoning posted Sat, 16 January 2010 at 9:24 AM
Question for you BB;
I used Anthanasius's Node Setup for a stained glass window. I don't thinkt the results would have been any different with yours.
When I delete "All" of the lights in the scene and use the 100% IDL Render Option, I get a very dark figure. I guess that is due to the "Ambient Value" being set at Zero. When i start to increase the Ambient Value of the one sided square I lose the Stained Glass Window.
Is there a way to use the "Blender Node" to increase the Ambient Value of the Stained Glass Window?
I tried increaseinf Cellular Intensity1 with a little better lighting.
TKS
DR
Thomas Jefferson
bagginsbill posted Sat, 16 January 2010 at 9:49 AM
A self-lit prop used as an IDL source of light must be either intensely bright or very large.
My IDL wall rectangles are intensely bright - with a luminance of 5 (on the unit scale, where 1 is the brightest value your monitor can show.)
A simple solution would be to copy the colored cellular node from Anth's shader into my light wall, and plug it into the tile node on both Tile_1 and Tile_2. Then the white * 5 rectangles would become those colors times 5.
Dead_Reckoning posted Sat, 16 January 2010 at 11:06 AM
As always BB, thank you very much for the information and learning.
Cheers
DR
Quote - A self-lit prop used as an IDL source of light must be either intensely bright or very large.
Thomas Jefferson
Believable3D posted Sat, 16 January 2010 at 1:20 PM
Note also that there are reflective surfaces in the light wall scene. I was able to turn the ambient value down below 1 and still have a relatively bright render, but that's because of the reflections.
______________
DarksealStudios posted Sat, 16 January 2010 at 2:18 PM
couple questions?
are you all using the p2010 beta for these renders?
do the render settings (other than turning on the global illumination) matter?
does the multiply in BB's render node tree make this brighter, or is it just for the pattern?
edit:
It's a nice pattern, I'd like to make something like this useful in p8 with the idirect lighting...just bright enough in p8
My Store   My Gallery    Contact
DarksealStudios posted Sat, 16 January 2010 at 3:28 PM
For p8, i guess you just turn up the volume (ambient value). I know I didnt do to much to the scene but here is a value of 5, then 15 in the ambient channel. Nice procedural BB, though I'm sure I did something wrong since I am getting a dark grey around the white...maybe I just didnt get true balck when making the nodes in one of the values.
edit: poser 8*
Dead_Reckoning posted Sat, 16 January 2010 at 7:58 PM
This time I used Edgeblend,ColoRamp,fBM connected to: Ambient Color
Used Apollo Space Marine and VP SciFi Room
Thomas Jefferson
Believable3D posted Sat, 16 January 2010 at 8:17 PM
That scene looks really good, mariner.
______________
Tashar59 posted Sat, 16 January 2010 at 11:00 PM
So what are your rendertimes like DR.
Dead_Reckoning posted Sun, 17 January 2010 at 6:10 AM
Quote - So what are your rendertimes like DR.
I just render the same scene again before posting my reply.
Total Time was 8.0 minutes
Pre-Calc time was 6.5 minutes
Render time was 1.5 minutes
Quad Core CPU
8 GB RAM
64Bit WinVista HP
Thomas Jefferson
Dead_Reckoning posted Sun, 17 January 2010 at 8:56 AM
This one took a little longer to Render
IDLApolloSpaceMarine Galactic War Zone
I had to compress it 15% to get it to post. Original does look better.
Thomas Jefferson
DarksealStudios posted Mon, 18 January 2010 at 8:19 AM
strange... mine took the same time but i have dual core (2.2ghz), 4 gigs ram and a non dedicated on borad graphics card on a touchscreen hp laptop. I would think your render would have been faster. My character here is about 124k polys, so it's kinda heavy and has 3 transparent mats!
Dead_Reckoning posted Mon, 18 January 2010 at 8:56 AM
OK, another question for you BB.
With Your Env Dome and Colm's Terra Dome, would this also apply to them as well?
If this is always true, MAYBE one of the talented Python Script Writers could make a Py to Turn Off both?
Thanks
DR
Thomas Jefferson
bagginsbill posted Mon, 18 January 2010 at 12:45 PM
This is not for the domes. It's for whatever material is trying to reflect other things, regardless of whether those are domes or figures or other kinds of props.
And somebody did post a request for a script to turn them off in all materials. But there are materials that are designed to compensate for this, and if you blindly turn this off, they will behave differently.
My instructions were with regard to your own workflow. When you start designing a material, your first step, in all cases, should be to turn them off.
The issue only arises because of using primitives and starting points for new things. When you load a primitive, you're going to want to edit its shader - you have to in order to even have any Reflect node in it. While you're there doing that, turn the Reflect_Lite_Mult off. (Or the other - whichever is turned on in all the primitives.)
rjjack posted Mon, 18 January 2010 at 2:20 PM
the result of my experiments,  except Aiko3, the hair and the dress everything in the scene is just poser primitives
