Forum: Photoshop
Subject: PhotoShop SetUp?
FranOnTheEdge opened this issue on Jan 16, 2010 · 6 posts
FranOnTheEdge posted Sat, 16 January 2010 at 12:49 PM
Hi, I recently had to put my Monster PC into surgery, so I've had to install Photoshop CS4 (and the rest of CS4 Production suite) to this lesser PC.
The specs aren't bad but I'm once again constantly irritated by Photoshop's insistance at opening images in a "glued on fashion" like this:
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
FranOnTheEdge posted Sat, 16 January 2010 at 12:50 PM
Instead of like this:
I've tried tweaking preferences but I can't remember what you do to correct it - can anyone help?
Fran's Freestuff
dreamer101 posted Sun, 17 January 2010 at 11:23 AM
Edit > Preferences > Interface > uncheck "Open Documents as Tabs"
That should do it if you want it to automatically open like that.
With the tabbed view you can always drag a tab to open as it's own window. Which you probably already know but new to me.
Going from CS to CS4 a week and a half ago, I've had to go through the preferences a lot.
FranOnTheEdge posted Sun, 17 January 2010 at 7:21 PM
dreamer101,
thanks very much.
Drag a tab?  Not sure what you mean by that - I'll have to investigate...
Fran's Freestuff
dreamer101 posted Sun, 17 January 2010 at 8:32 PM
If you have tabbed documents you can drag a tab down. It will break it away from the tab docking area creating it's own window. You can also do the reverse. If you have all separate windows you can drag window up until it docks back as a tab.
FranOnTheEdge posted Thu, 21 January 2010 at 12:31 PM
Oh I see, well in that case that's what I was doing to separate the images, now I know what it's called.  Thanks.
Fran's Freestuff
