Forum: Photoshop
Subject: Creating PDF Files?
Lzy724 opened this issue on Jan 22, 2010 · 8 posts
Lzy724 posted Fri, 22 January 2010 at 8:14 AM
Does anybody have any tips on this? I've tried a few times after setting up the files but every time I save it to pdf, it looks horrible?
Are there certain settings or sizes that should be used?
dreamer101 posted Fri, 22 January 2010 at 10:41 AM
It all depends on what you plan to do with the PDF file. Is it for viewing on the web or printing? I'm a CS4 virgin LOL. I went from CS to CS4 2 weeks ago. I've been going through video tutorials from lynda.com . I think the main settings would be the Adobe PDF Preset and the Compatibility. Choosing Press Quality for the Adobe PDF Preset and Acrobat 5 or higher for the Compatibility works pretty good. You don't have to fiddle around with individual settings as each preset will have it's own settings.
Lzy724 posted Fri, 22 January 2010 at 5:47 PM
yep. piddled till I felt I couldnt piddle anymore and they all came out horribly ugly and crappy. so I guess I am doing something wrong big time.  but I am using 7.... so that may be the issue...??
zollster posted Fri, 22 January 2010 at 6:05 PM
have ya tried using the default settings? :)
dreamer101 posted Fri, 22 January 2010 at 6:55 PM
You could even save it as a PSD in Photoshop then use Adobe Acrobat to create a PDF from the PSD. Vector will always make a better PDF than with raster.
Lzy724 posted Fri, 22 January 2010 at 7:39 PM
I have zollster. :D
Will try that dreamer... I have the pdf writer at work, just not here... nothing seems to give me something decent.
Quest posted Sun, 24 January 2010 at 11:11 PM
Here are a couple of sites that I found helpful before I lost the contents I was putting together for a tutorial PDF several months ago in crash:
http://www.adobe.com/designcenter/acrobat/articles/acr6pppshop.html
http://www.wipeout44.com/brain_food/multipage_pdf.asp
retrocity posted Mon, 25 January 2010 at 9:55 PM
 Are you creating the PDF from a single layer or from layer comps ?
i've used the "print as PDF" and the scripts that come in the FILE --> SCRIPTS --> Layer Comps to PDF menu... and even the FILE ---> AUTOMATE --> PDF Presentation worked out okay for me...
what are some of the requirements of your project?
scott
