benign_lump opened this issue on Jan 26, 2010 · 14 posts
benign_lump posted Tue, 26 January 2010 at 1:20 PM
The number of tris and n-gons is minimal, I don't necessarily plan on exporting the model for use in another program, but I'd rather have that option, so I'm trying to use safe modeling methods. The drivers (spoked wheels) and counterweights and frame extensions bolted to the back of the frame probably add another 20,000 polys (at least, just guessing). And it's just going to get bigger.
Is this a high count for Carrara? The program seems to handle it so far with no problem. I imagine shading and lighting will affect render time to a greater degree than poly count. Is that a fair assumption? What would be considered the high end, or too many polys? I know a lot depends on the computer.
Thanks
MarkBremmer posted Tue, 26 January 2010 at 1:35 PM
Hi BL,
When Carrara slows down really depends on your system's memory - but any time you start getting up to 100,000 "real" polygons, sytems tend to slow down a bit.
I think that you may be setting yourself up for difficulties as the model progress. I'd suggest using a combination of different modeling tricks to keep things under control. For example, the piece you highlighted can easily be created in the Spline modeler yet render with full fidelity. The Spline modeler will create something that is about 1/1000 the memory and poly count yet will render as if it's made up of thousands of polygons.
Another thing I'd suggest is using low poly objects but using Carrara's Subdivision capabilities in the Vertex room. This will yield much smaller file sizes by high definition renders. The subdivision modeler is akin to working with NURBS in other modeling applications.
Ultimately, it's a hobby it sounds like so do what you like. But as long as you are learning to model, there are some other good modeling tricks to pick up. ;-)
benign_lump posted Tue, 26 January 2010 at 1:53 PM
Thanks for the feedback Mark,
Worked thru most of your C6 tutorial at VTC, just starting on C7 tut. I'll try out your tips on the spline modeler for certain, I want the best detail for the least overhead. I don't mind doing something over if I can make it better. And this thing is only about 10% along so I need to be efficient as possible without losing detail.
Thanks again,
Mike
ShawnDriscoll posted Wed, 27 January 2010 at 2:42 AM
Looks very good so far. Are you using booleans?
benign_lump posted Wed, 27 January 2010 at 8:41 AM
Mark-
I actually imported the profile of the locomotive frame into the spline modeler (without all the bolt holes - added those later) then converted it to vertex. And, I'm just guessing here, I probably ended up using too many quads (did I say too many? meant to say WAY too many). At a glance, there's only one tri visible in the attached screen capture from the vertex room (just found another).
The model is supposed to be cast and machined steel, I want the bolt holes to be smoothly round so I've got 32 quads per hole right there (I can see a high fidelity spline model helping here). Then I transition the geometry from the hole to the flat plane of the frame side, and next thing you know I'm drowning in quads.
Am I too hung up on quads and tris? I may never send the model to another program, but I do want to use sound modeling techniques, just in case. While I want model efficiency, it is a complex machine, it will be a big model, a big file. I just can't let it get out of hand. I need to explore the spline modeler, I like the fact you can keep a model simple and jack up the fidelity for rendering.
Can you assign shading domains in the spline modeler?
By the way Mark, I go back to RayDream 2.5 (? or 3, can't remember) and went to Carrara when 1 came out (although I probably upgraded 2 or 3 times before I did more than open the program!). I probably learned more after an hour or two of following your VTC tuts as I did in 15 years on my own. Great tuts, thanks!
Anyway, back to work.
Mike
MarkBremmer posted Wed, 27 January 2010 at 10:08 AM
Hi Mike,
Thanks for the kind words. Glad the tuts helped out.
The spline modeler actually assigns shading domains automatically. You an rename them though. Essentially, it's front, back and then one for each side - in this case, the interior of each hole. For a shape like this, I'd do a full line version in Illustrator including the holes and set up my compound holes there and just import it to Carrara.
A note on triangles vs. quads: The purest will say that you should only use quads. This is true for organic shapes that will be bending like people and animals etc. However, for hard edge shapes, it really doesn't matter. As long as you can crease edges, the flat spots can be either quads or triangles. The only difference is, that every quad adds geometry to your file because of hte extra edge and point. Quads can be a little easier to work with in the UV editor, though.
Mark
benign_lump posted Wed, 27 January 2010 at 10:40 AM
Well okay then, If tris aren't such a bad thing for a chunk of steel, that alone would make a big difference if I simply chose to go back and edit in the vertex room, I could easily cut the number of polys in half - or more. But I did run through the spline modeler tut last night and want to try a spline version. And I remember the automatic domain names, now that you mention it, because I deleted them and added new ones. Too much 3d, not enough time.
I work in Corel and export to Illustrator. My initial frame profile with just the large holes as a compound shape came into the spline modeler great, so I can go back and add the smaller bolt holes.
I guess you just have to consider each part and pick the most appropriate modeler.
Thanks again,
Mike
ptsulli posted Thu, 28 January 2010 at 10:08 AM
Mike;
Quote - I guess you just have to consider each part and pick the most appropriate modeler.
This is exactly right, and is as true for the guys with multi-million dollar render farms and Maya/3DS/Lightwave as it is with those of us that do this as a hobby. Sub-division, bump mapping and displacement maps are all tricks that were developed to keep the poly count below the crash and burn memory thresholds (and speed rendering time of course.). For hard edged objects you can't beat the spline modeler.
Not trying to insult anyone's intelligence, only throwing out ideas.. If I were doing your loco. I'd probably do most of it in the spline modeler, except for the cab and the backhead of the boiler. I would probably add the rivets on the smokebox, boiler, and firebox with displacement maps and probably model the staybolts as the 3d equivalent of NBW castings (nut-bolt washer) with surface replication, but that would be me, I tend to build 3d models as if they were here in the real world with me, and there are a thousands ways to do it. My other hobby is model railroading so I tend to get a little carried away.
My standard plug for Mark's classes, you can't beat them, and I've tried most of the classes available on DVD/online..
R/S
Patrick "Sully" Sullivan
benign_lump posted Thu, 28 January 2010 at 11:22 AM
I've only recently come back to model railroading after being away from the hobby for 35 years, and really the only modeling I'll probably do is in 3D. I'm actually more of a reborn railfan. By the way it's a D&RGW K-36.
I've been using this software at work since RayDream but haven't really pushed or immersed myself fully into the program - it's not that hard to model and texture an aerosol can, after all. I've been honing my skills in the vertex modeler, looks like I'll have to dive into the spline modeler just as deeply as long as I can get the same degree of accuracy.
I'll keep posting my progress.
Mike
holyforest posted Mon, 01 February 2010 at 8:16 AM
Nice job so far!
Holyforest,
Hundreds of shaders for
Carrara
benign_lump posted Sat, 06 February 2010 at 9:42 AM
Mike
benign_lump posted Sat, 06 February 2010 at 9:59 AM
Mike
MarkBremmer posted Sat, 06 February 2010 at 11:04 AM
I'm not sure why the other images aren't showing up on the texture map issue. You might also create a hole using the circular layer map tool. You can convert the blank layer shader to a multi-channel and then load in an color in the color channel and black in the alpha channel and you'll have an instantaneous hole.
ShawnDriscoll posted Sat, 06 February 2010 at 11:16 AM
Looks great. I love aging stuff, too.
