wrpspeed opened this issue on Feb 01, 2010 · 9 posts
wrpspeed posted Mon, 01 February 2010 at 8:20 PM
Hello, I got a new computer and installed poser 6 on it. at
a screen resolution of 1280 X 720 , the memory dots dont
show. at screen resolution of 1920 X 1080, the memory dots
appear but everything is tiny. my bad eyesight prevents me from
using this resolution . does anyone know a procedure to relocate
the memory dots into the visible area of the screen at
1280X720? i have tried to restall poser but it didn't fix it.
thanks for any ideas.
geep posted Mon, 01 February 2010 at 8:33 PM
Attached Link: http://www.drgeep.com/p5/introp5/introp5.htm
*(click image to view full size) (click link above image to view tutorial)*The above was done for Poser 5 but might help.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
wrpspeed posted Mon, 01 February 2010 at 8:40 PM
thanks Dr Geep. I have tried everything there. I am at
1920 X 1080 with big icons and still nothing.
geep posted Mon, 01 February 2010 at 8:44 PM
Change the screen size so the Dots are visible?
Move the Dots?
Minimize Poser?
Change the screen size?
Restore Poser?
Set the "Preferred State?"
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Mon, 01 February 2010 at 9:02 PM
Try using the "Window" menu to hide other Tools and see if the "Dots" are hiding under something.
cheers,
dr geep ... :o]
edited 10/5/2019
wrpspeed posted Mon, 01 February 2010 at 10:12 PM
Dr . Geep, I have done al those things.
geep posted Mon, 01 February 2010 at 10:14 PM
Sorry, I was just able to duplicate your problem. No Dots visible on 1280x720 screen.*
Note - at screen resolution of 1280 x 768, the Dots are just visible in the lower left corner
Do you have this option? Can you use?
cheers,
dr geep ... :o]
edited 10/5/2019
wrpspeed posted Mon, 01 February 2010 at 11:07 PM
Dr. Geep. Think I solved it. I used maximum resolution and then opened up
poser.The memory dots were visible in the lower left. I took it and piled everything
else in the center of the screen and saved them as preferences. I then reset
the resolution back down to 1280 X 720 and then opened poser. It was barely
there in the lower left . I rearranged all the items back to their correct positions
and saved them in preferences. I tried and opening poser again and everything was
there. Thanks for all your help.
geep posted Tue, 02 February 2010 at 5:48 AM
SUPER!
I'm glad you solved it.
Glad to help anytime.
cheers, (and happy rendering)
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
