Thu, Feb 27, 7:46 AM CST
Renderosity Forums / 3D Modeling
Welcome to the 3D Modeling Forum
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 23 7:48 pm)
Freeware 3D Modeling Software Links:
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the
MarketPlace Wishing Well, as a content creator's resource for your next project.
"What 3D Program Should I buy?" Not one person here can really tell you what's best for you, as everyone has their own taste in workflow. Try the demo or learning edition of the program you're interested in, this is the only way to find out which programs you like.
Subject: how to make an obj into a prop??
SickenlySweete ( ) posted Thu, 11 February 2010 at 8:47 PM · edited Fri, 19 July 2024 at 8:46 AM
with out poser??
any stand alone programs out there?
found a script for daz studio but am unable to install it correctly apparently........lol
thanks
SS
www.bloodyrosesdesigns.com
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
markschum ( ) posted Fri, 12 February 2010 at 1:15 AM
Poser creates a pp2 file which contains some geometry, texture info and the object pivot point and an end marker.  I dont know of any programs apart from poser that will create one
In Poser its a simple import obj, save to library, done.
EnglishBob ( ) posted Fri, 12 February 2010 at 3:33 AM
file_448019.txt
This is a blank prop file: if you edit it with an external geometry file it may work, but without any way of testing it, I personally wouldn't risk it.
I assume you want a Poser file to distribute to people who have Poser? It might be better to just send the OBJ file. If you can export one with a good MTL file it should be easy to import with its material settings intact. Let us know if you want something testing.
