mrsparky opened this issue on Feb 13, 2010 · 15 posts
mrsparky posted Sat, 13 February 2010 at 9:02 PM
Created an OBJ of a room with around 8 parts. Nothing need to move - just need to use show/hide poses.Bring the model create figure use the hirechary editor and it looks OK until you select a part and then it totally distorts.
any ideas?
TIA
kyhighlander59 posted Sat, 13 February 2010 at 9:08 PM
If it is distorting when you bend a joint then you need to fix it in the joint editor. I can't tell from the picture what is going on. You could do a before distortion and an after to be a bit more accurate.
mrsparky posted Sat, 13 February 2010 at 9:18 PM
The idea is to setup it up so I can use show/hide poses on some parts like 2 roofs, and the 2 ends.
BTW - Please ignore the cr*p render - it's 3.15am here and I'm getting ready to either retire or fix the problem with a large axe :)
basicwiz posted Sat, 13 February 2010 at 9:21 PM
Really dumb question from the peanut gallery...
Why do you need to do it with mat poses? If it's made in pieces does each piece not have a visibility switch???? That's how I do it with rooms I build from primitives.
$.02
markschum posted Sat, 13 February 2010 at 9:31 PM
there is a parameter in properties panel called BEND , make sure thats off.
If you are using Poser 6 or higher you can make it a prop, and use material collections to apply transparency to turn areas on or off. a mrlcollection will apply to a prop where a mat pose may not.
kyhighlander59 posted Sat, 13 February 2010 at 10:18 PM
If your not wanting it to have a joint why did you go through the trouble of making it a figure in the setup room?
ockham posted Sat, 13 February 2010 at 10:25 PM
The setup room may have created some default positions that aren't zero.
That's the only way I can imagine distortion caused merely by selection!
Change all
bend 1
to
bend 0
in the CR2 then load and resave. This will cure the distortion but may
not cure the default position.
I never use the setup room for house-type things, always use PHI files.
Quicker and more certain, no weird surprises.
EdW posted Sat, 13 February 2010 at 10:49 PM
I normally turn bend off in the properties tab of the parameters panel then save the figure back to the libraray On a room like this Iuse the hierachy editor to create the figure.. make the walls and ceilings children of the floor.. then hit the create figure button.... just make sure you have the floor selected:)
mrsparky posted Sun, 14 February 2010 at 8:14 AM
ockham - the bend = 0 did the trick!! thank you! mucho grasis! merci! Cheers! danke!
*Really dumb question from the peanut gallery...
*Why do you need to do it with mat poses?
The OBJ is one single model with groups.
I want to use show/hide poses to show/hide groups like as the ceiing shown in the 2nd image.
Nice tip thanks.
I have P4, PP, P6, P7 and P8 :)
But I also want to make sure that the model works in other apps like studio, carrara and vue.
So things like P6+ materials are out.
So it can take MAT poses for maps and the show/hides.
I did consider making it a single figure and then just maxing the transparency on the materials for that part. I made the room 1st and then added bits, with the idea being some maps can be shared amongst parts, thus reducing texture load.
Thats important. Because theres something like 20 parts here, and while the mapping has been carefully optimised (ie: dials and meters are larger to avoid the fuzzys) it's still a "heavy" model.
Some of the meshes are also large, again (as you can see from this model) because of all the high level of detail. Especially the ones with cables.
Some reduction has been done on maps and meshes, but there is set point where you can't reduce stuff without losing too much.
*there is a parameter in properties panel called BEND , make sure thats off.I normally turn bend off in the properties tab of the parameters panel then save the figure back to the libraray On a room like this Iuse the hierachy editor to create the figure.. make the walls and ceilings children of the floor.. then hit the create figure button.... just make sure you have the floor selected:)
I tried that :) But I think I got the order of doing things wrong!
Usually other people kindly rig my stuff for me, this time I thought I'd give it a try:)
PS EDW - replying to your IM shortly.
markschum posted Sun, 14 February 2010 at 9:01 AM
The Bend parameter in the properties panel does the same thing as ockhams Bend = 0 edit. I have a python script that I use when rigging mechanicals. I find phibuilder works very well. Gets you quickly to a rigged figure, then you just need to set bend , and adjust pivot points.
kyhighlander59 posted Sun, 14 February 2010 at 9:18 AM
mrsparky posted Sun, 14 February 2010 at 10:40 AM
*I find phibuilder works very well. Gets you quickly to a rigged figure, then you just need to set bend , and adjust pivot points.
*LOL I need to add this thread to my Poser Tome of Knowledge.
nomuse posted Sun, 14 February 2010 at 1:16 PM
I'm right in the middle of rigging some props now (that do have some moving parts) so let me just chime in on a few things...
Yeah, turn off bend for non-organics. Easy enough to do that in Poser, in the parameters, but you can also do a search-and-replace in text. Unfortunately, if you have a morphing prop you actually need the bend on for that actor...that's when you need to struggle with the joint params.
Instead of MAT poses setting materials to transparent, consider using hide/unhide actor instead...that can be saved in the same kind of library file as the MAT pose.
As a third alternative, make sure you have dummy objects for the "invisible" poses, and create altGeom dials.
JHoagland posted Sun, 14 February 2010 at 3:08 PM
Attached Link: Making a Refrigerator Figure, Part 2
My contribution to the Tome of Knowledge thread... my [Making a Refrigerator Figure](http://www.cocs.com/poser/makingfigure2.htm) tutorial.Step 1 is building the model in Lightwave, but this page covers:
-Removing 1 and 2 point polygons before exporting
-Separating Materials and Groups (body parts) for modelling programs that don't export Group information
-Building the Hierarchy/ phi file
-UV Mapping/ why you should split the vertices
-Turning Bend off
-Setting the joint centers
-Editting the cr2 file to lock the joints
nomuse posted Sun, 14 February 2010 at 4:00 PM
Aha. I like the trick of setting limits to 0 and using "Force Limits." All I've been doing is hiding the dials.
I model in Carrara, and one of the steps in that program is the much-loved "Normals dance." For whatever reason, Carrara tends to reverse the surface normals on every other instance or duplicate of a master object (but not always...it's basically random). So before doing the final split and grouping, I import into Poser and look for reversed normals. And as it turns out, it is faster to fix them in Poser, too, using the grouping tool.
