lancerdoom1 opened this issue on Feb 15, 2010 · 6 posts
lancerdoom1 posted Mon, 15 February 2010 at 3:18 AM
guys, i want to make roads on the mountains in VUE 8 like we do in geocontrol 2 using vector path.
please help if anybody find a way?
bruno021 posted Mon, 15 February 2010 at 4:12 AM
You can't use vector path in th eterrain editor, but you can sculpt your raod with the new sculpting tools, even with the old 2D ones, and by using the clipping planes to limit the carving.
lancerdoom1 posted Mon, 15 February 2010 at 2:10 PM
how can i sculpt the roads on mountains in vue 8 using clipping planes you say..?
bruno021 posted Mon, 15 February 2010 at 4:13 PM
At the bottom of the terrain editor, you have a slider that goes from zero to 100, if you move those sliders, the one on the left up, the one on the right down, you will change the clipping planes positions, so you can put them almost next to one another to limit the carving. To be able to see the planes, you have to activate the "Show clipping planes" button, it's the 7th from the left at the top of the editor. Now that your planes are in place, you can use a 2D brush (I would recommend you create your brush yourself in Photoshop or the like, a square black brush would be best, and there are no such brushes already available in Vue). Before sculpting, you need to activate the "constrain to clipping plane" box. Then use the "Raise" brush, but check the "Invert" box before starting sculpting.
lancerdoom1 posted Wed, 17 February 2010 at 2:56 AM
is there any other easy way to create roads on the mountains?
any plugin ?
also is there any tutorial on creating roads in geocontrol 2 and export it in vue 8 ?
Mazak posted Wed, 17 February 2010 at 3:50 AM
Here you can find a Winding road tutorial: http://www.cajomi.de/Forum/showthread.php?t=860
GeoControl to Vue tutorial 1: http://www.perpetualvisions.com/new-articles/tut-gc2-vue/tutorialgc2-vue.html
GeoControl to Vue tutorial 2: http://www.virtual-lands-3d.com/geocontrol-2-vue1.html
And finally you can find here my free scene with an road as example: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2780641
Mazak
