tunggulaja opened this issue on Feb 15, 2010 ยท 5 posts
tunggulaja posted Mon, 15 February 2010 at 3:44 AM
So I just upgraded to a new hardware with Windows 7 (Athlon II X4 630) and installed my Poser 8 there. Here's the problem:
Each time I want to run poser, it always gives me the pop dialog box asking me "Are u sure to run it?" (something like that). How do I disable the pop up?
Why Poser 8 won't use 100% all of the four cores I have? In the task manager what I see is around 30% to 60% only.
Thanks//
Lucifer_The_Dark posted Mon, 15 February 2010 at 4:32 AM
Mine is switched off as I like to sail close to the edge of the world. ;)
Windows 7 64Bit
Poser Pro 2010 SR1
thefixer posted Mon, 15 February 2010 at 5:27 AM
I run a quad core with Poser 8 and windows 7 Ultimate, like Lucifer the UAC is switched off.
I rarely use Poser 8 to render though, if at all..
Injustice will be avenged.
Cofiwch Dryweryn.
Dizzi posted Mon, 15 February 2010 at 6:26 AM
Only Poser's renderer will make use of all available cores and only if you set the number of threads in preferences correctly..
hobepaintball posted Mon, 15 February 2010 at 8:42 AM
mine runs all 4 cores at 100%. Win7 64bit no uac. Threads set in preferences to 4 render in a serperate process. I'm building an i7 as soon as DDR3 memory comes down a little more (last time i checked 24gig was $2500.00 US) if you are on 32 bit, reformat and start again, you will be very very happy.
