goido opened this issue on Feb 15, 2010 · 5 posts
goido posted Mon, 15 February 2010 at 11:48 PM
Ok, after many years of using my Epson 1270 it finally died. I just got an R1900, it came with a link to Epsons ICC profiles. My question is should I calibrate my system first with my also new X-Rite software and then install the profiles? This would be my first time profiling my monitor, scanner and printer; so I am thinking I should calibrate first and then install the Epson new profiles.
Any advice would be appreciate it.
Andres
inshaala posted Tue, 16 February 2010 at 2:53 PM
All i know is that the whole thing is a ball ache - i'd read the manual and anything you can find online before you begin anything.
Contact Meowgli - he set up his rig to do the right profiles etc - coming to think of it i think danob might also be able to help here too. Just set aside a day at least where you have the time to just do it and run a load of test prints etc.
Rich
"In every colour, there's the light.
In every stone sleeps a crystal.
Remember the Shaman, when he used to say:
Man is the dream of the Dolphin"
Rich Meadows Photography
goido posted Tue, 16 February 2010 at 9:25 PM
Thanks Rich, I will need aday for the initial profiling and lots of diffrent paper :)
danob posted Sun, 21 February 2010 at 6:23 AM
As with Epson's previous printers, the R1900 provides built-in profiles for all of the company's papers. However, the driver doesn’t provide any way for installing new profiles, which can be frustrating if there’s a third-party paper that you really want to print on. Also annoying: The driver doesn’t automatically deactivate its own colour engine if you choose to have your host application manage colour. This is just one more setting you can forget to change that would then ruin a piece of potentially expensive paper.
Danny O'Byrne http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
Onslow posted Thu, 04 March 2010 at 3:40 PM
You're saying you will need lots of different paper ?
Are you making your own profiles? or using ICC ones.
If you are using ICC profiles you only need to download a ready made profile from the papers maker. This will give you colour calibration that is acceptable for all but the most exacting needs. I would advise against making your own profiles unless you have the equipment and experience.
You can however move up one step from the ICC profiles by having profiles specifically written for your printer/ paper combination by a lab. who specialises in this type of work. They will ask you for a sample print of colour patches from files they send you. These are then returned to them for analysis by Spectrophotometer and they will write the profile from the result. This is a very accurate way managing colour printwork, each individual printer varies slightly in what it will produce and ICC profiles are standard. This is imho over the top though unless you have a specific need for this level of accuracy.
You say it is your first time working with a colour managed workflow. My advice would be to calibrate your monitor first. Then decide which colour space you want to work in (your working space) and set your software to use this colour space. Most people use aRGB though there are others, all with their own merits.
Next set your photo. software so it is setting the the colour handling. Next set the rendering intent, for which most people use 'relative colorimetric' and select 'black point compensation'.
Doing this you will be able to proof your images on screen before actually printing.
I used lots of generalisations here to keep it simple but I am happy to go further into any part if you want more information.
It all sounds much more complicated than it actually is. Once you are used to using colour management your results will be much more pleasing and consistent.
Then it is time to start experimenting with different colour spaces and rendering intents :- )
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
