Casette opened this issue on Feb 21, 2010 · 13 posts
Casette posted Sun, 21 February 2010 at 1:33 PM
Hi folks
I'm on the verge of a of a nervous breakdown. I'm trying to apply a Muskateer Graphics' Superman second skin to M3, but I can't use correctly the mask node. Anyone can save my brain and post a node tree pic?
The texture: http://www.muskateergraphics.com/freebies/files/MGSuperman.zip
Thanks.-
CASETTE
hborre posted Sun, 21 February 2010 at 4:14 PM
dlfurman posted Sun, 21 February 2010 at 4:19 PM
Okeesdoekey :)
No images but you CAN do this.
Load up M3.
Go to Material Room .
See the Poser Surface Box. Click the button/plug thing right next to DIFFUSE (at the very top)
You will see a box appear that says NEW NODE.
Click that and a new box with a list of options. Look for 2D Textures. Click the arrow next to that and click image_map**.**
In those dialog boxes put the color image of Superman.
In the very same POSER SURFACE find the BUMP or DISPLACEMENT or GRADIENT BUMP or GRADIENT MODE and do the above.
For the image map place, this time use the node.
Or if you want pictures, go back to MuskateerGraphics and Click TUTORIALS and look for the MAT TUTORIAL (Its the only one) :) and see the explanation there.
space
hborre posted Sun, 21 February 2010 at 4:36 PM
Dlfurman: there are only 2 texture maps in the file, 1 image, the other a transmap. I showed the easy setup in the material room. I could easily create a much more complicated node tree for better detailing.
Casette posted Sun, 21 February 2010 at 4:46 PM
**@hborre
Your settings were that I used after writting this thread. With that tree the neck appears in** black**...
CASETTE
hborre posted Sun, 21 February 2010 at 5:40 PM
hborre posted Sun, 21 February 2010 at 5:44 PM
Casette posted Sun, 21 February 2010 at 5:47 PM
But my Superman is using a M3 texture. If i do your settings, his neck looks like chewing gum. The default M3 color doesn't work for me
CASETTE
hborre posted Sun, 21 February 2010 at 5:53 PM
And I agree. The other work around is to use a blender node with your M3 texture to combine both maps.
Casette posted Sun, 21 February 2010 at 5:55 PM
Just that hell of combination is what I'm searching for... :(
CASETTE
hborre posted Sun, 21 February 2010 at 7:07 PM
hborre posted Sun, 21 February 2010 at 7:09 PM
Casette posted Sun, 21 February 2010 at 7:32 PM
WOW! Thanks !!! :D
CASETTE
