Subject: My rendering is almost all black ?!
beatone opened this issue on Apr 24, 2001 ยท 5 posts
beatone posted Tue, 24 April 2001 at 12:09 PM
Hi all, I created some text using Amorphium and importet it into Poser, first as 3ds, later as Obj. Now when I render this text is comes out all black? Everything else renders ok... Have any of you had the same problem or do you have a solution to this rether annoying problem? Cheers, Beat One
pdblake posted Tue, 24 April 2001 at 1:00 PM
Did you UV map it?
beatone posted Tue, 24 April 2001 at 4:38 PM
ehhh huh ?!
sama1 posted Tue, 24 April 2001 at 6:13 PM
Looks like the reflection map is enable under the render materials. I had this problem before, where it looks great untill you render. The solution is to set the reflection map to None. Poser uses a different type of reflection map then other programs; Poser reflects from a spere surrounding the space where the object is intead of mapping from the surface of the object which other programs use. I hope this helps. Sam
flyerx posted Wed, 25 April 2001 at 5:57 PM
There may be no normal information in the file. I had this happen to me with DXF files. See if you can export the file with normals from Amorphium. good luck, FlyerX
