Subject: Exporting poser 6 to photoshop
Tom42 opened this issue on Feb 27, 2010 · 10 posts
Tom42 posted Sat, 27 February 2010 at 12:32 PM
Hi, wanted to know if anyone has exporting poser 6  character  to photoshop?I found  about poser 7 exporter, but dont find any about poser 6 exporter. any infor be extremely appericate
BAR-CODE posted Sat, 27 February 2010 at 2:36 PM
and in what format is that character exported ???
And what do you mean with character ?? model, texture, 3d obj ..???
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
Tom42 posted Sat, 27 February 2010 at 4:16 PM
it poser model. female character. going from poser to photoshop. got it to photoshop using obj, but in photoshop she turn sideway. plus  was hope you could turn her around. beable make her bigger  .
RobynsVeil posted Sat, 27 February 2010 at 8:56 PM
That are you trying to achieve in Photoshop with an obj file? Just curious... I thought Photoshop was more for processing/manipulating image files, not 3D object files...
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
Khai-J-Bach posted Sat, 27 February 2010 at 9:38 PM
Photoshop CS 3 and 4 will import OBJ files for texturing.
tho how well I don't know (Photoshop 7 here)
dlfurman posted Sat, 27 February 2010 at 9:56 PM
It works fine, but....if you have a object with several materials (ie the V4 Bodysuit) you are going to get layers for each separate material (like 7 for just the leg alone).
I'm still trying to find a way to paint, and collapse the layers all into one layer and kick it out for use in Poser (There is something I must be missing).
William the Bloody says it works for him, and I believe him!
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD space
RobynsVeil posted Sat, 27 February 2010 at 10:58 PM
Well, for V4 I'd be using SnowSultan's maps to texture on (see bottom of that page)... no point in re-inventing the wheel. And for the V4 Bodysuit... same solution (see bottom of that page). Or am I missing something here?
Metaphor of Chooks
BAR-CODE posted Sun, 28 February 2010 at 6:54 AM
That how to turn etc is written in the manual and the pdf of Photoshop.
So that should not be a problem to figure it out by just reading them.....
Quote - it poser model. female character. going from poser to photoshop. got it to photoshop using obj, but in photoshop she turn sideway. plus  was hope you could turn her around. beable make her bigger  .
Chris
My Free Stuff
dlfurman posted Sun, 28 February 2010 at 7:52 AM
Quote - Well, for V4 I'd be using SnowSultan's maps to texture on (see bottom of that page)... no point in re-inventing the wheel. And for the V4 Bodysuit... same solution (see bottom of that page). Or am I missing something here?
You can do that way for sure, but using Photoshop 3D tools is like DeepPaint or Blacksmith3D-Paint. or BodyPaint from Maxon, only more familiar.
With the flattened UV map where you think something is may not translate well when you have the model in Poser and in 3D. I do 3D versions of the comic book costumes I drew in 2D and well....sometimes we do not get an exact match, especially when you cross seams or if the UV map is not exactly set up symmetrically.  Also you can paint where you want to as opposed to trying to match a distance or spot that is not exactly on a vertex or on an edge.
Tom42 posted Sun, 28 February 2010 at 8:52 AM
Thanks for all the help. just thought you could do it with poser and photoshop. in maya you can export model and turn it all different way in photoshop. what do texture on the model, but want beable to view all around the model. i will do more reading and try what all you have told me. thanks everyone.
Tom
