fairyfantastic opened this issue on Mar 07, 2010 · 5 posts
fairyfantastic posted Sun, 07 March 2010 at 2:17 PM
hi all i have made a clothing item after a few weeks battling with getting it to conform properly well i mastered tht ok but nowi sent to a friend who is texturing it and iot wont accept the texture map even wen its uv mapped it still wont accept texture now imnot sure if it ther way i export from hex or import to poser wen weni have tested un tried to texture with and with out uv i have same problem to all normall are forward on cltohing does ant one have any tips on why this is happening thks paula
BAR-CODE posted Sun, 07 March 2010 at 2:30 PM
not accepting the texture ... if its not the right UVmap or the obj got changed a bit after being mapped the uvmap wont look right.. but i can put ANYTHING on a obj that has any uv map..
So what is the problem exact ?
I can help if you like ..IM me here at RO if you want some help ...
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
markschum posted Sun, 07 March 2010 at 3:30 PM
I would load the obj file into UV mapper (free edition is fine ) and check the UV map . If that looks all right then you need to start looking at material groups. Or send the obj to someone for a look.
BAR-CODE posted Sun, 07 March 2010 at 3:36 PM
Im already helping her out off site ..
Its as it looks like its not a UVmapper error ..but a little "beginner" error
we get it right for sure ...
Chris
kyhighlander59 posted Sun, 07 March 2010 at 3:47 PM
