persius opened this issue on Mar 13, 2010 · 5 posts
persius posted Sat, 13 March 2010 at 4:41 PM
Hello
Can anybody please suggest any methods where I can smooth out the tops of mountains so they aren't so pointy & rough. Where do I need to go in order to make adjustments?
Thank you.
gillbrooks posted Sat, 13 March 2010 at 4:53 PM
To get something like the preview here, open the terrain editore and click on 'filter altitudes', edit filter and there change from a straight line to 'smooth curve'
After ok-ing out, also click on the diffusive erosion on the effects tab a few times
Gill
persius posted Sat, 13 March 2010 at 5:08 PM
Thanks so much for replying. I'll give it a try now.
Cheers
ShawnDriscoll posted Sat, 13 March 2010 at 8:19 PM
I sometimes edit the terrain (depending on what I have or don't have driving the terrain) and click the Paint tab and choose Touch-up. Then I can Airbrush the tops of hills using a Falloff.
bigbraader posted Sun, 14 March 2010 at 5:21 AM
I might also suggest the use of the undo/redo tool in the terrain editor (a little like the "History Brush" in Photoshop): If you want some areas rough and others smooth e.g., use a function to produce the roughness, "Undo" this, and then paint the roughness back in the areas you want with the "Redo" tool (or vice-versa, smoothen the terrain, "Undo" and paint the smoothness back). You can also smoothen specific areas with the "Effects" tool, use "Diffuse Erosion".
