J9tRTXW1 opened this issue on Mar 13, 2010 · 4 posts
J9tRTXW1 posted Sat, 13 March 2010 at 5:36 PM
How to download rederotity zip into Daz 3
mishamcm posted Sat, 13 March 2010 at 5:43 PM
Unzip the Rendo item to a temporary location. The root should be the Runtime folder. Merge that with a Poser-format runtime knows to D|S.
SentinelJeff posted Sun, 14 March 2010 at 11:07 PM
It's easier than that if you haven't installed winzip. I just double click the zip file and then drag or copy the runtime folder into the content folder. Windows treats it like a real folder without unzipping it.
SilverDolphin posted Thu, 18 March 2010 at 10:01 PM
If you use winrar just open the archive and drag the file onto the studio content folder.
Next Windows will ask you if you would like to merge runtime folders click yes.
Viola you are done.
PS. this only works if the files are setup for poser use.
If the files are for Daz Studio use you may have to drag the file onto the Studio folder.
You can see if it is for poser if the file is set up as runtime or Runtime if it has Content for root then it has been setup for Daz Studio.
Hope this helps.
