chrisfm64 opened this issue on Mar 18, 2010 · 6 posts
chrisfm64 posted Thu, 18 March 2010 at 11:12 PM
I hope someone can advise me. Poser dynamic hair strikes me as something that looks really great theory wise but doesn't seem practical especially in animations due to the looooooong time needed to calculate it. I read somewhere that Carrara can calculate Poser dynamic hair faster than Poser proper. Is this true? If not has anyone found any techniques to do the hair calcs faster?
holyforest posted Fri, 19 March 2010 at 6:04 AM
Carrara has its own dynamic hair and fur system, very fast and realistic.
Carrara is a very good software.
Holyforest,
Hundreds of shaders for
Carrara
jfbeute posted Fri, 19 March 2010 at 9:53 AM
Actually the hair system in Carrara is better in many aspects than Poser. But it isn't really much faster, given the same quality of hair. Often you will find that you can get away with a somewhat lower quality setting and thus gain some time.
The one thing missing in Carrara is the cloth system which isn't easy to export from Poser.
Sueposer posted Fri, 19 March 2010 at 12:09 PM
The hair in Carrara does take a long time to calculate (slightly faster, but not much, than poser). There are a few tricks to speed it up.
If your character has only one side to the camera, you can delete the unseen hair.
The number of segments per hair can be drastically reduced.
You can place fewer, but thicker hairs on the head, this is okay for distance, but not close up renders.
You can use a prop hair and place a few animated hair strands on to it. This way you have a good head of hair, but can still animate some whispy bits.
ThetaLov posted Mon, 22 March 2010 at 8:18 PM
Quote - You can use a prop hair and place a few animated hair strands on to it. This way you have a good head of hair, but can still animate some whispy bits.
Why did I never think of this before? And here I was killing my wrist by painting!
Sueposer, you're awesome.
drewradley posted Tue, 23 March 2010 at 3:58 PM
There is a tutorial over at DAZ that shows an easy way of exporting Poser cloth for use in D/S and it works in Carrara as well. I use this technique all the time and it couldn't be any easier.
http://www.daz3d.com/i/tutorial/tutorial?id=1543&_m=d
Now Playing
My Insomnia Presents
Blue Defender
