Subject: PoserFusion 2010 For 3dsMax poser pro 2010
darkasylum opened this issue on Mar 19, 2010 · 18 posts
darkasylum posted Fri, 19 March 2010 at 9:09 AM
when installing Install Poser Fusion 2010 for max 32 and 64 bit,
when trying inport into 3dsmax 32 & 64 bit. the program will not inport
poser files. see enclosed screen dumps
any one else having these issue?
the serail are valid ! any one help? i posted it to the support forums on SM also
BAR-CODE posted Fri, 19 March 2010 at 9:17 AM
THE 3Dmax SAYsthat the 3DmAXu use is UNREGGED . maybe thats the problem with the serial and not poser??
better ask at Autodesk official forum how and what ..
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
darkasylum posted Fri, 19 March 2010 at 9:46 AM
yes i am useing trail version on 2010, 64 bit
the 32 bit version is regged, and has the same probelms
Saluki posted Fri, 19 March 2010 at 12:12 PM
I believe PoserFusion was built to work with Max 9 (and it does from my experiments) but doesn't appear to be compatible with Max 2010 (I get the message "DLL PzrFor3ds.dlo failed to initialize. Error code 127 - The specified procedure could not be found" when Max is initializing).  Checking the Poser docs it makes no mention of Max 2010 but specifically mentions Max 9...
darkasylum posted Fri, 19 March 2010 at 12:34 PM
are you using PoserFusion 2010? asd there are 32bit version and 64 bit version
it the version that came with poser pro 2010,
i check the docs again also
Belladzines posted Fri, 19 March 2010 at 1:04 PM
Where is the installer for poserfusion for PP2010?
darkasylum posted Fri, 19 March 2010 at 1:09 PM
hi its,
in Installers> 3DSMAX on the main cd of poser pro 210
**Artemis. your on devaint art? sure i know that icon?
any way.
Saluki
yes PoserFusion in Poser Pro 2010 does work with 2009 and 2010 versions of 3Ds Max.
John Csaky | Customer/Tech Support
Smith Micro Software, Inc. | www.smithmicro.com
Belladzines posted Fri, 19 March 2010 at 1:13 PM
i am on DA but my username there is Dragonfly3d and i did post the image of this avatar there also.
darkasylum posted Fri, 19 March 2010 at 1:28 PM
ah yes , i know as the maskdemon on there
http://maskdemon.deviantart.com/
think we talked about poser pro and background renders
just waiting for SmithM help diesk to get back to me!
Belladzines posted Fri, 19 March 2010 at 1:35 PM
Added you to my watch there :)
i bought poserpro online and i cant find poserfusion for it ..... very confused.
darkasylum posted Fri, 19 March 2010 at 1:53 PM
i won my copy, did you down load all the files there are 3 files
PoserPro2010Installer.zip< should be in here
PoserPro2010Content.zip
LegacyContent.zip
charlesatlas posted Fri, 19 March 2010 at 2:11 PM
I am having the exact same problem with poser pro 2010 and Maya.
Belladzines posted Fri, 19 March 2010 at 2:40 PM
Quote - i won my copy, did you down load all the files there are 3 files
LegacyContent.zip
yes i did, is it in one of the menus in PP?
i have to admit i havent explored it at all, i just went in and did work .....
darkasylum posted Fri, 19 March 2010 at 2:51 PM
ah right, the info so far!
check the following
C:ProgramDataPoserFusion3dsMax2.0
yours may say maya?
or delete the files and reinstall
PzrFor3ds.ini
[POSER]
POSER_LOCATION=e:program files (x86)smith microposer 8
PzrFor3ds.dta
see if that works i have open a support ticket with SIMTHm
CAN YOU POST YOU errors please?
this may not fix your problem, i think it big bug they have not checked
yes i did, is it in one of the menus in PP? (no you can only see it 3ds max) not in poser pro 2010
Belladzines posted Fri, 19 March 2010 at 3:12 PM
it didnt install on its own, i did find the installer for poserfusion so i'll install it manually.
darkasylum posted Fri, 19 March 2010 at 3:23 PM
then you will need open 3dsmax, you find it there!
ratscloset posted Fri, 19 March 2010 at 9:30 PM
Just a word of warning.. issues with Maya are different that Max (and MAC is different that Windows) I only say this because we have had a few users get confused by reading about something in Forums that did not apply to their situation and caused more problems...
for your issue.. if you still have troubles, contact Support... if you have not already..
I was quoted here... put Attn John in the Subject and I will look for it.
ratscloset
aka John
jeffg3 posted Sat, 20 March 2010 at 12:37 AM
Bottom line... Poser Fusion sucks.
