Subject: Poser 8 question.
shadowhawk2zero opened this issue on Mar 23, 2010 · 5 posts
shadowhawk2zero posted Tue, 23 March 2010 at 9:29 AM
Hi all,
     I recently installed a copy of Poser  on my computer and I have a question. When I load a figure it shows up as a wire frame and I have to go through the menus to get the textures to show up. Am I doing something wrong, or is there a way to get a loaded item to show up textured instead of wire framed? Or is this just something that I will have to deal with using Poser 8? If that is the case I will just remove it since I don't like to have to go through all the steps to see a texture I am working with.
wimvdb posted Tue, 23 March 2010 at 9:45 AM
Press on the "document display type"  gadget the "texture shaded" button. Then go to Edit!General Preferenced": and make sure that on the Interface tab "launch to previous state" is selected
WandW posted Tue, 23 March 2010 at 9:45 AM
You must have it set to show the wireframe view instead of smooth shaded.
With an empty scene, in the Document Display window, click on the texture shaded ball (at the lower right).
Then, go to Preferences, make sure sure it is set to open to preferred state, and click the Set Preferred State button.
DOH!! Curse my metal body-I wasn't fast enough! 😄
markschum posted Tue, 23 March 2010 at 9:47 AM
You should have a set of circles that set the display attributes. Select the one at the far right for texture shadinged.
shadowhawk2zero posted Tue, 23 March 2010 at 10:06 AM
Thanks for all the info everyone, it worked great! Now I can go ahead and start using Poser 8. I appreciate all the help you guys offered and it was so quick! YOU ALL ROCK!!
