Subject: Windows 7 and Poser...
CMKook-24601 opened this issue on Mar 29, 2010 · 8 posts
CMKook-24601 posted Mon, 29 March 2010 at 9:54 PM
I had heard some where that Poser was not working correctly with Windows 7 is that still the case?
if it maters I am running poser 8 (on an old XP POS)
LaurieA posted Mon, 29 March 2010 at 10:03 PM
I was just running Poser 8 today on my Windows 7 64 bit NETBOOK ;o). Runs just fine :o). That's with only a 1 gig Cely and 2 gigs of ram btw...
Khai-J-Bach posted Mon, 29 March 2010 at 10:03 PM
nope. it is not the case at all.
install poser 7 outside of Program Files or alter your UAC (User Account Control) and posers 5,6,7, Pro etc run just fine.
(I'm running the above on Windows 7 64bit, installed outside of the Program Files folders with no issues.)
LostinSpaceman posted Mon, 29 March 2010 at 10:04 PM
I have Poser 6, 8 and Pro 2010 installed on Windows 7 Pro 64Bit and they all three run just fine.
LaurieA posted Mon, 29 March 2010 at 10:05 PM
Yep, forgot to mention I have Poser 8 installed on my netbook outside of the program files folder :o) I also might mention I also run P8 on an older Vista POS desktop on which it also runs fine...lmao.
CMKook-24601 posted Mon, 29 March 2010 at 10:07 PM
 Thank you all soooo much
hobepaintball posted Tue, 30 March 2010 at 6:14 AM
Since I have UAC turned completly off so Vue will run I installed Poser in it's default directory with the runtimes in their classic location and have had ZERO problems, P7, P8 Pro2010
vilters posted Tue, 30 March 2010 at 9:40 AM
Just install it, under >Program files or elsewhere.
Just do NOT install the runtimes there.
Put those under your user folders.
I think, it is the uppermost option during the content installation process.
I run Poser 8 and Poser Pro2010, on anything from a quadcore with 6GB RAM to a netbook (N270 CPU with 1GB RAM) without problems.
Windows 7 Home Pro 64 bit
Windows 7, 32 bit
Windows 7 Starter (on the netbook)
Windows XP 32 bit
Poser 8 became pretty stable after the SR2.1.
PoserPro2010 never gave installations or operational problems. (touch wood)
