Forum: Bryce
Subject: mirror surface for bryce 5.5
bimph opened this issue on Apr 01, 2010 · 7 posts
bimph posted Thu, 01 April 2010 at 4:05 AM
If this is a dumb question please forgive me.  Ive looked through the preset rollup this afternoon on 5.5 for a nice mirror surface.  I cant seem to find one.  Maybe its there and I am passing over it.  If not - can anyone recommend where I might get a hold of some mirror and mirror like surfaces.  Thankyou.
erosiaart posted Thu, 01 April 2010 at 4:47 AM
int he freebie area.. or at cgshare. Cool mats there.Check in the metal section of the presets.. you'll be able to find some mat there that you can tweak/edit to increase it into a mirror. I know I've seen a mirror mat somewhere there.
or do a search for mirror textures..and import it using the da vinci guy in the mats lab.
cheers
nazul posted Thu, 01 April 2010 at 5:46 AM
Look in metals - bright metals - there should be a mirror, however it has a distinct blue colour in its diffuse witch i suggest you make light grey instead or else all reflektions will have a blue tone to it
bimph posted Thu, 01 April 2010 at 6:54 AM
Thankyou both so much for this - metal is a good idea - and why didnt I think of it?
IO4 posted Thu, 01 April 2010 at 9:26 AM
You can make a mirrored surface really easily - just use these settings in the material library. I'm using Bryce 6 but if my memory is correct there should be no difference :
Reflection - 100
Specularity -100
No other settings are needed, but of course you can play around and see what works best for your object/scene.
Beginners tutorials for Bryce
Bryce Arena
bimph posted Sat, 03 April 2010 at 9:59 AM
Just brilliant 104 - thanks for taking the time here and much appreciated.  btw - Out of Step is a marvellous piece - congratulations on this one.  Not just for your technical expertise - but for the ambience and the emotion conveyed.
IO4 posted Sat, 03 April 2010 at 10:20 AM
Thank you very much!:) Nice of you to respond and to check out my gallery too:biggrin: Happy Easter:)
Bryce Arena
