Doran opened this issue on Apr 01, 2010 · 3 posts
Doran posted Thu, 01 April 2010 at 9:02 PM
OK, the problem is that I have shaders in my animation, the wet and wounded shaders to be exact. Of course, in a still render they look fantastic but when I create an animation the shaders move across the body. Understand that no material room nodes for these shaders are animated in any way. Every texture node, hell... every thing in the material room is set to be static so I am assuming that I have missed something concerning the use of shaders.
Is there something I must do when applying shaders to keep them static during a Poser animation.
bagginsbill posted Thu, 01 April 2010 at 9:19 PM
I can't see the shaders so ... just guessing.
Are any of the nodes set up to use global coordinates? If so, the patterns will remain fixed in space. As your figure moves, it will pass through these features that are floating hidden in space until your figure intersects them with his/her skin.
Doran posted Thu, 01 April 2010 at 9:23 PM
That's why you are the MAN! Thank you very much BB :) Problem solved :D
