Darboshanski opened this issue on Apr 05, 2010 · 6 posts
Darboshanski posted Mon, 05 April 2010 at 5:24 PM
I will try to describe my problem clearly. Over the weekend I installed a new 1TB internal hard drive and then moved all my linked poser external runtime folders to it because my C: drive was getting a little bit too crowded. Poser Pro and Poser Pro 2010 had no problems finding the content so all was good there. Then I had an issue with Vue ( 7 infinite ) and had to re-install it so of course I had to re-set all my preferences and the poser import. when I checked the poser import status in my preferences it was on Poser Pro okay good then I didn't have to change anything.
My problem is this anytime I create a scene in Poser Pro and then import it into Vue it seems Vue can't find a blessed thing now. It asks me for everything .obj files, textures file the whole shooting match it as if something did work when I set my poser import.
Vue will ask me to manually hunt down each and every texture, obj, trans map, etc for example"
"Can not find Runtime/textures/pangopango/blue.jpg would you like to find it manually?" as you can see there isn't even a drive letter just "Runtime". So I am lost on how to fix this even if I were to move things back to the C: drive it defeats the purpose of having another drive for more space.
My Vue content is on the E: drive (New drive) and has no problem finding things like .vobs and scenes.
So does anyone have a clue as to what I should do? I find it funny that after a new install of Vue that my poser import and my general preferences were really not changed or at least gone back the default settings?
Any help would be appreciated!
Thanks!
