zorzim opened this issue on Apr 06, 2010 · 9 posts
zorzim posted Tue, 06 April 2010 at 7:08 AM
Hi everyone,
from time to time I wonder how to render a HUGE thermonuclear explosion.
I'm relatively new on Vue, but the main problem with it is the flaming/smoke material
of the mushroom.
Any help regarding mats and thing would be appreciated
zorzim posted Tue, 06 April 2010 at 4:56 PM
Any idea regarding the material to be used for the "mushroom" cloud ...?
Also I would ask if it effective to use a geometry like mushroom to fill with aforedmentioned mat, or its best to try metaballs or a series of spheres...
ShawnDriscoll posted Tue, 06 April 2010 at 9:23 PM
I played with the laithe profile curves for mine recently.
http://4.bp.blogspot.com/_P8p1y5m2z7A/S4zpvJ-V8AI/AAAAAAAAAG4/qFcBIJqZ4ns/s1600-h/nuke2.jpg
zorzim posted Wed, 07 April 2010 at 5:58 AM
Thanks Shawn,
your render reflects almost exactly what I had in mind... what version of Vue are u using, and what's the cloud mat ?
ShawnDriscoll posted Wed, 07 April 2010 at 11:38 PM
I'm using the Stretched Stratus cloud with:
Altitude 0km.
Height 10km.
Cover 68%.
Density 98%.
Opacity 81%
Sharpness 8%.
Feathers 5%.
Detail amount 5%.
Altitude variations 0%.
Ambient lighting 60%.
Shadow density 60%.
For the mat's Cloud layer detail, I'm using:
Scaling 25%.
Roughness 59%.
Variations 45%.
Uniformity 58%.
The Custom cloud layer profile is the image above. The left side is the bottom (ground shockwave). The right side is the top of the mushroom. The top is the profile shape that gets spun around the Z axis. Somewhere around the middle is the Z axis (0.00 level). The top I have go negative so that there is some air pressure at the top going on. Just a trial mockup.
I'm using Vue Infinite 8.
zorzim posted Thu, 08 April 2010 at 5:58 AM
Yours is a remarkable accomplishment in that direction. I mean, as a starting point is really ok, but there is a way to render it more like a gigantica mass of water instead of ... a gigantic amass of vapour...?
ShawnDriscoll posted Thu, 08 April 2010 at 5:14 PM
If you model the same shape as polygons (with displacement and/or hyper texturing applied), you can then use any material for it. My test was to see what I could model using only the Spectral Cloud v2 portion of Vue.
zorzim posted Sun, 11 April 2010 at 12:08 PM
Any suggestion on how to do a billowing fire mat for it its welcome...
Cherryman posted Sun, 11 April 2010 at 2:00 PM
Maybe this helps:[
I could really use an animated mushroom
cloud.http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3502440&ebot_calc_page#message_3502440
](http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2798440)
