Dave-So opened this issue on Apr 10, 2010 · 14 posts
Dave-So posted Sat, 10 April 2010 at 4:56 PM
Its been awhile since a motorcycle thread was posted. Please list motorcycle products or freestuff for Poser etc.
Here are a couple of them. these are some of my favs, but there are more here on Rendo if you do a search for motorcycle. Also in freestuff.
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=22509 Pixelmagic CHOPPER
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=32906&vendor=PixelMagic PixelMagic AVENGER
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=66164&vendor=29204 Pretty 3D Road Eagle
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=4889&Start=61&vendor=6400 Billy Ts chopper very nice, plus addons for it. A bit pricey.
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=74245&keyword=motorcycle
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=63017&keyword=motorcycle&list=title
http://www.daz3d.com/i/3d-models/-/american-hog-motorcycle?item=278&_m=d DAZ American Hog
there are more at DAZ do a "motorcycle" search
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
gibby.g posted Sat, 10 April 2010 at 5:36 PM
mrsparky posted Sat, 10 April 2010 at 7:47 PM
Attached Link: http://www.poserdirect.com/witchbikeposer.html
Link above - don't be put off the name if you want a traditional brit style bike. Remove the cauldron and you have one.Dave-So posted Sat, 10 April 2010 at 7:58 PM
thanks so far :)
that witch bike will look real good riding through the rubble :)
Humankind has not
together.
1854
R_Hatch posted Sat, 10 April 2010 at 9:14 PM
Nice sci-fi/experimental bike: ** TWEMC01** by motokamishii.
pakled posted Sun, 11 April 2010 at 6:43 PM
aw, man...;) I remember there was one poster of some incredibly-detailed bikes, 3-wheelers, etc., the files were huge (dozens of megabytes). The person either pulled them all off the web, or something to that effect. If I could remember which of 20-odd thousand files it was. I saw it in the Daz freepository, a few months back.
raven posted Mon, 12 April 2010 at 10:55 AM
Attached Link: http://www.morphography.uk.vu/dlcatamaran.html
pakled, I believe they are Catamaran's bikes. He sadly died, and now EnglishBob hosts them. Available at the link.Dave-So posted Mon, 12 April 2010 at 5:05 PM
that BWII is mighty nice.
Quote - pakled, I believe they are Catamaran's bikes. He sadly died, and now EnglishBob hosts them.
Humankind has not
together.
1854
Dave-So posted Mon, 19 April 2010 at 7:03 PM
well...a NEW CHOPPER !!
http://www.runtimedna.com/Chopper.html
not sure i totally like it .. appears to be not much detail, especially in the engine area, but otherwise looks very good.
Humankind has not
together.
1854
gaff posted Tue, 20 April 2010 at 8:13 AM
Quote - Attached Link: http://www.morphography.uk.vu/dlcatamaran.html
You guys made my day...
Poserworld got a nice Chopper.
http://www.poserworld.com/Downloads/Props/9944/Chopper.aspx
You can take a look at it here in my gallery:
http://www.renderosity.com/mod/gallery/index.php?image_id=2047488
Cheers
lmckenzie posted Wed, 21 April 2010 at 9:08 AM
Attached Link: http://www.honda.co.jp/WebPlamo/
The site is in Japanese but fairly easy to understand. Click on a model on the main page to get a listing of the individual parts.
The models are available in .dxf and .lwo (Lightwave format) - you probably want the latter.
Tricky Part 1: For some reason the links to the Lightwave (.lwo) versions of the files no longer show up in any browser I tried but the files are there. Right click on the dxf download button and select "copy link location" (Firefox) or whatever the option is in your browser to copy the URL. Paste it into an editor or the address bar and replace "dxf" in the URL with "lwo". Thus for the Dream 50 bike:
http://www.honda.co.jp/WebPlamo/dream50/parts/dxf/body-A.zip
Becomes:
http://www.honda.co.jp/WebPlamo/dream50/parts/lwo/body-A.zip
Tricky Part 2: On the Dream 50, the headlight filename in the URL is misspelled, you need to change "hesd_light" to "head_light". I don't remember misspelled files for any of the other bikes I downloaded some time ago (I think this one is new), but you may run into others - if so, try using the name as listed on the parts page.
Download all the parts for a vehicle in this manner and save them in a folder and unzip all of them there.
Download PoseRay (http://mysite.verizon.net/sfg0000/) In PoserRay:
Click Load->3D Model and in the file open dialog, navigate to the folder where you unzipped the parts.
Hold down shift and select ALL of the .lwo files at once and click Open. PoseRay will ask you for a name for the combined parts (I used "Honda Dream 50"). It will then load and assemble the parts into the bike which you can see in the preview (check "Enable Preview" in the Preview tab.
Tricky Part 3: I chose the worst example apparently. There were missing .psd texture files which PoseRay will complain about but the model loaded fine.
Tricky Part 4: To avoid missing texture errors in Poser, open the .mtl file (that PoserRay creates with the .obj export) in a text editor and delete the "Map" lines that refer to the missing texture files OR deal with the missing maps in Poser OR open the .obj in UVMapper and and deal with it there. I suppose you could also create some dummy image files with the same names - up to you, I just deleted them.
This is a quickie Vue render of the .obj model (with the texture references removed from the .mtl file). It's a bit of work but once you've done one, the process is fairly easy.
The tricky parts with textures etc. may or may not show up with some of the other models. I used to have all of them but apparently I lost them at some point. I tried downloading the City Cabriolet car, which I think I used to have, and now some of the .lwo files seem to be corrupt so things may have changed with the site/files since then - such as the invisible .lwo links. It's a hassle but you can get some nice, realistically detailed free models. You can try converting the individual parts and assembling them yourself. I don't know if Poser will import them in the correct positions as .obj or as .lwo if your version of Poser imports .lwo directly.
lmckenzie posted Wed, 21 April 2010 at 9:13 AM
jonesy90 posted Wed, 21 April 2010 at 6:11 PM
Attached Link: http://blog.zgock-lab.net/poser/sub3.html
Shukky has got a free Sportsbike available called the WAKASAKI.Just scroll down toward the bottom of the page.
On the Honda site, I was able to use Opera to display the hidden links to the Lwo files, by using the links panel and filtering by .zip
P.s How do you imbed images in a forum post.
lmckenzie posted Wed, 21 April 2010 at 7:17 PM
*" On the Honda site, I was able to use Opera to display the hidden links to the Lwo files, by using the links panel and filtering by .zip:"
Smile - That's exactly what I did since I use Opera, but I'm afraid that we're probably in the minority. Using the filter is a good idea - I usually forget it's there.
"P.s How do you imbed images in a forum post."*
Look down below the Reply block for "Attach a File:" and click on "Choose" to select an image file to display in your post.
